It is currently Wed Sep 17, 2025 1:23 pm
Reply to topic  [ 15 posts ]
 Mudd, here comes Da Muttmotor!
Post Mudd, here comes Da Muttmotor!
First let me say thanks to the guys at EVT for modifiying their manifold for me.
Also I'd like to say thanks to Mudd for finish/adjustment work on the flanges, I got it bolted on and running this morning.
Got some fine tuning to do and going to build a hard linkage setup so as to retain the original PD style throttle.
Fri Jul 10, 2009 1:19 pm
Post Re: Mudd, here comes Da Muttmotor!
Very nice!
Benefits of the S&S over the HSR? (just curious)
Fri Jul 10, 2009 1:38 pm
Fri Jul 10, 2009 2:00 pm
Looks Good Myboy! Sure wish you lived closer, I would like to give you a hand with that throttle!
Are you still running off the governor?
Fri Jul 10, 2009 8:54 pm
Sat Jul 11, 2009 6:31 am
It has to be good if it comes from Viola, WI!! :D :D
What model and size? I got a few mid to late 80's S&S carbs laying around/
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Sat Jul 11, 2009 9:07 am
Sat Jul 11, 2009 10:10 am
replied to your pm.. I hope I'm wrong.. :P
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Sat Jul 11, 2009 6:01 pm
Excellent
Ill get into the linkage parts I have here and see what we can do.
Sun Jul 12, 2009 1:03 pm
Looks good; if I could ask, what are the angles sandwiched around the support brackets of the BPS for? I'm curious due to the fact that I'm having some issues with mine.
1648 PD w/36FPR
Wed Jul 15, 2009 7:01 pm
Looks awesome........Might have to take the S & S off the sporty and in stall it on the mud motor. What kinda rigging on the exhaust did you do?
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Wed Jul 15, 2009 7:15 pm
Wed Jul 15, 2009 7:20 pm
Can you elaberate a bit. I cracked mine on one of hte tig welds on the left head flange, along with the left support bracket @ the 90 degree bend. I'm guessing that the angles are connected to the alum. plate just below the clutch for added support ?
1648 PD w/36FPR
Wed Jul 15, 2009 7:39 pm
Wed Jul 15, 2009 7:56 pm
Thanks for your help, I was wondering is I was the only misfortunate one; glad that there is a sight like MMT and for good mudders like yourselfto share data.
I thought of tig welding some small gussets in the middle of the bracket bends, and simply v out the crack and tig up. But did not want to void any warranty. If I hearing you correctly BPS will probally ship the brackets to up-grade the supporting of the new exhaust assembly.
Again thanks.............
1648 PD w/36FPR
Wed Jul 15, 2009 8:12 pm
