Rev limiter????? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32176 |
Author: | Barroll [ Sat Sep 08, 2012 1:11 pm ] |
Post subject: | Rev limiter????? |
So my old revlimiter got wet because my boat almost sank so I had to replace it. I got a new one from mudbuddy and hooked it up and the motor would not start. If I clip the green wire it will instantly start. I was told that it was just a bad limiter so I sent it back for a new one. Well I have a new one now and it is doing the exact same thing. Black wire grounded on starter, green connecting into other green wire, and red on the clutch circuit breaker. Im stumped and I also hate electrical things so it is frustrating me. Any help would be appreciated. |
Author: | take'emgator [ Sat Sep 08, 2012 1:40 pm ] |
Post subject: | Re: Rev limiter????? |
You may not have a rev limiter problem, check all your wires and where they connect and make sure there is no corrosion and they are still attached, make sure you have a good ground |
Author: | naj [ Sat Sep 08, 2012 3:19 pm ] |
Like he said Sounds like bad connection or something is grounding out. |
Author: | Team Camo [ Sat Sep 08, 2012 4:32 pm ] |
Try moving the red wire to a different hot. It needs power even when in the "start" position |
Author: | Barroll [ Mon Sep 10, 2012 3:49 pm ] |
So Im still stumped. I moved it to a different ground and different hots. There is a white wire that was hidden in the insulation and not sticking out. Is that wire for anything. Also what does the green wire do? Seems like it is the one causing me issues. |
Author: | coonass381 [ Mon Sep 10, 2012 3:55 pm ] |
I got a new one in july and it quit working last weekend |
Author: | take'emgator [ Mon Sep 10, 2012 7:34 pm ] |
Green wire is what goes too your coil wire. Its possible you got another bad one, but its rare but possible |
Author: | Barroll [ Mon Sep 10, 2012 9:22 pm ] |
Author: | take'emgator [ Mon Sep 10, 2012 10:42 pm ] |
If you hooked it up the same way as your last one and its doing the same thing, and when you unhooked the green wire it runs fine..... it can be one of two things, either they sent a bad box OR you got something going on with your ground and with your positive, and if its the ground positive thing, hook the hot to the hot side of your battery and the ground to the ground side of your battery, hook the green wires up and try to start it, if it still messes up then its for sure the box. Cause then you know you have a good ground and positive and its not either one of those. |
Author: | Barroll [ Tue Sep 11, 2012 3:30 pm ] |
Author: | take'emgator [ Tue Sep 11, 2012 3:35 pm ] |
When you say the motor will not start does that mean it'll turn over and won't fire off or it won't do nothing at all when you hook it up like its suppose to be |
Author: | Barroll [ Tue Sep 11, 2012 3:37 pm ] |
Author: | Team Camo [ Tue Sep 11, 2012 3:39 pm ] |
Use a volt meter to find a hot that's dead when key is off, hot when key is on or in start position and hook your red wire to it. Then ground it to the block. |
Author: | take'emgator [ Tue Sep 11, 2012 7:12 pm ] |
That wouldn't explain the ticking in the rev box would it? |
Author: | Team Camo [ Tue Sep 11, 2012 7:30 pm ] |
The box clicks when it powers on, but shouldn't continuously click. |
Author: | richard nagon [ Tue Sep 11, 2012 8:38 pm ] |
camo's right on the wiring. power to box with key on. barroll there are plenty of rev limiters out there. that have adjustable rpms as cheap as $50.00 to 130.00 dollars. that have lighted tachs - hour meter. adjustable in 250 rpm increments. and have ranges from 2500 rpm to 7000 rpm. have soft or hard cut-out. and high rpm recall. the way to go if future mods are in the future. the ones that i've seen from out west are soft cut-out. and can range wildly from what they claim as a rpm cutoff. they also have two stage limiters. u just don't wire in the first stage. that go for cheap |
Author: | Barroll [ Tue Sep 11, 2012 9:45 pm ] |
The box only clicks when it gets power one time. Richard. Where can I find one of these? will they work for this application? |
Author: | richard nagon [ Wed Sep 12, 2012 4:41 am ] |
Summit - jegs eBay is loaded with them. Otto Makes a fine one. |
Author: | AKA Freshwaterkilla [ Sun Sep 16, 2012 9:14 pm ] |
I had my rev limiter on my motor for two months got to landing to hunt made it 20 yards and motor started spitting popping and sputtering like it had a fuel problem I checked fuel lines bulb was hard so I tried to run it a few more mins kept doing it then it killed and it wouldn't start at all pulled plug wires no fire so I cut wires off of rev limiter box motor fired rite up and run like a bat out of hell |
Author: | take'emgator [ Sun Sep 16, 2012 9:34 pm ] |
sometimes they go out, i've been through 2 of them, i jsut run without one now, gotten use to it |
Author: | AKA Freshwaterkilla [ Sun Sep 16, 2012 9:45 pm ] |
Yea I think that's what I'm doing too |
Author: | dguidry [ Sun Sep 16, 2012 9:46 pm ] |
Mine hasn't run right since I installed last year. No spark or fuel pump in start positing. Starts only in run position. I'm disconnecting it tomorrow and gonna let 'er run wild. |
Author: | take'emgator [ Sun Sep 16, 2012 9:50 pm ] |
YOu can run without it you just got to be real careful with a stock internal motor cause it won't take high RPMS very well if you hit something and the motor kicks up. With my motor i have a little more room for high RPMS but not much when i run shallows i don't run it WO. But in deep water i let her eat |
Author: | Barroll [ Sun Sep 16, 2012 10:24 pm ] |
Ive been running without a limiter all summer. I just hold the tiller so when i hit something it just knocks it out of my hand instead of trying to grab it harder and squeezing the throttle even more. But I havnt had a problem. I just wont be able to let other ppl drive this year unless I can get it fixed |
