It is currently Fri Jul 18, 2025 10:19 am
[ 3 posts ] |
gtmorgan89
 Fuel Pump question.
I just purchased a motor with a 24 hp Honda on it. I cannot get it to crank and run without 'crank in a can' or pouring a little gas in the carb. It have tried gravity, a bulb pump, and a 4-10lb fuel pump I had laying around. It sees like I am either getting too much or not enough fuel for this this motor to run.
Any recommendations"? or does anyone know what sort of fuel pressure these things need to rrun. I assume not much since most mowers are gravity fed and the small pump in from of the carb.
any help is appreciated. thanks
Mon Sep 10, 2012 8:01 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
 Re: Fuel Pump question.
Your needle valve under the float may be stuck or your jets are gummed up if it will crank and then die as soon as it burns what you sprayed in it even when trying to gravity feed it
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
Mon Sep 10, 2012 8:08 pm |
cb5331
Or the fuel solenoid is fucked.
Mon Sep 10, 2012 8:09 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 117 guests |
