It is currently Fri Jul 18, 2025 4:09 am
Reply to topic  [ 4 posts ]
 pd clutch "skipping a beat"
Post pd clutch "skipping a beat"
I have been reading the other posts about clutch problems on PDs. Mine will momentarily disengage running WOT for a second and then re-engage on its own. I am thinking it could just be the switch but what do y'all think?
Mon Sep 10, 2012 5:48 pm
Post Re: pd clutch "skipping a beat"
Switch, bad connection, low voltage
Mon Sep 10, 2012 6:00 pm
Could also be a voltage loss somewhere before getting to the clutch. I just went through this last weekend with somebody. He described the symptoms to KP and KP suggested checking for a voltage loss. I metered it and it was 8.5 volts directly at the connectors going into the clutch.
Meter your battery and see what the voltage is. Put a meter on the two connections going to the clutch right where the connector is going to the clutch and see if you have the same voltage. If it's a lot less, you have a bad wire somewhere or corrosion on a connector somewhere.
Mon Sep 10, 2012 6:01 pm
Will do, thanks.
Mon Sep 10, 2012 8:15 pm
Users browsing this forum: No registered users and 86 guests
