pd clutch "skipping a beat" http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32257 |
Author: | duckhead75 [ Mon Sep 10, 2012 5:48 pm ] |
Post subject: | pd clutch "skipping a beat" |
I have been reading the other posts about clutch problems on PDs. Mine will momentarily disengage running WOT for a second and then re-engage on its own. I am thinking it could just be the switch but what do y'all think? |
Author: | Beadlejuicejr [ Mon Sep 10, 2012 6:00 pm ] |
Post subject: | Re: pd clutch "skipping a beat" |
Switch, bad connection, low voltage |
Author: | woffman [ Mon Sep 10, 2012 6:01 pm ] |
Could also be a voltage loss somewhere before getting to the clutch. I just went through this last weekend with somebody. He described the symptoms to KP and KP suggested checking for a voltage loss. I metered it and it was 8.5 volts directly at the connectors going into the clutch. Meter your battery and see what the voltage is. Put a meter on the two connections going to the clutch right where the connector is going to the clutch and see if you have the same voltage. If it's a lot less, you have a bad wire somewhere or corrosion on a connector somewhere. |
Author: | duckhead75 [ Mon Sep 10, 2012 8:15 pm ] |
Will do, thanks. |
