It is currently Thu Jul 17, 2025 5:16 pm
Reply to topic  [ 7 posts ]
 engine guru's, need help
Post engine guru's, need help
Its a damn shame but I finally got around to installing Cody's heads and have everything set. (Been working alot). I think I'm missing a linkage to my carb to control the gas. When I started it up, I had no control and gas was pouring out the carb (had air filter off to check things). Also I think the black adjustment knobs (air/fuel) are out of wack. But that is the least of my worries, need that linkage. Problem is motor was taken apart and heads sent out before Hurricane hit. Piled stuff in shop. Not I think Its somewhere in shop. Anybody have a pic of the stock carb with the "so called Linkage"
Tue Sep 11, 2012 6:37 pm
Post Re: engine guru's, need help
Its the governor linkage. Where can I get one and would that cause the gas shooting out the back of my carb?
Tue Sep 11, 2012 7:03 pm
Send me a pic of what you need and $5 for shipping. I have 2 linkages here from mikuni installs.
Tue Sep 11, 2012 7:09 pm
Remember a wire type linkage.
Tue Sep 11, 2012 7:58 pm
This?
Tue Sep 11, 2012 8:46 pm
Yep, I believe that's it, unless someone says otherwise. Now would that cause the fuel to be coming out the carb while running?
Wed Sep 12, 2012 4:34 am
Let me know if you want it. I can just stick it in a regular envelope and send it out. But might be quicker to pick the part up at a small engine shop if you need it by Friday or Saturday. In in Tallahassee fl.
Wed Sep 12, 2012 5:48 am
Users browsing this forum: No registered users and 109 guests
