It is currently Fri Jul 18, 2025 7:20 am
[ 4 posts ] |
pd clutch "skipping a beat"
duckhead75
I have been reading the other posts about clutch problems on PDs. Mine will momentarily disengage running WOT for a second and then re-engage on its own. I am thinking it could just be the switch but what do y'all think?
Mon Sep 10, 2012 5:48 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: pd clutch "skipping a beat"
Switch, bad connection, low voltage
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Mon Sep 10, 2012 6:00 pm |
woffman
Joined: Tue Jan 13, 2009 6:35 pm Posts: 208 Location: WI
Could also be a voltage loss somewhere before getting to the clutch. I just went through this last weekend with somebody. He described the symptoms to KP and KP suggested checking for a voltage loss. I metered it and it was 8.5 volts directly at the connectors going into the clutch. Meter your battery and see what the voltage is. Put a meter on the two connections going to the clutch right where the connector is going to the clutch and see if you have the same voltage. If it's a lot less, you have a bad wire somewhere or corrosion on a connector somewhere.
Mon Sep 10, 2012 6:01 pm |
duckhead75
Will do, thanks.
Mon Sep 10, 2012 8:15 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 101 guests |
