It is currently Thu Jul 17, 2025 5:12 pm
[ 8 posts ] |
Engine problems -2008 Gator-tail 35 GTR
cforstall
Hi everyone, I sure hope someone here can answer my question. Today, I went teal hunting and my engine was running really slow (1200 rpms) when in the water but once you lift the engine out the water or on the trailer it runs normal (3600 ). I could get the rpms to go up a little when I applied a little choke but still not much better. I'm thinking it's a carburetor problem but I'm not sure. Any help would be greatly appreciated.
Chris
Sun Sep 16, 2012 1:19 pm |
CCC
 Re: Engine problems -2008 Gator-tail 35 GTR
Your "normal" 3600 is low also.
Sun Sep 16, 2012 2:00 pm |
odass
Bad gas? Maybe your governor isn't set right
_________________ Dead Fowl Custom 1954hd with a GTR
Sun Sep 16, 2012 2:03 pm |
marsh chicken
Is it backfiring a lot? And does it sound like both cylinders are firing? Could be a spark plug coil or wire grounding out. ESP if you run salt water. Make sure everything is insulated....if you can run it in the dark, you can often times see where it's arching out at. Also make sure you have a good seal on your carb boot. Lastly check your governor linkage, make sure it's set correctly and hasn't slipped.
Sun Sep 16, 2012 5:24 pm |
bubba777
My buddy gtr did that his carb bolts were loose causing to suck air it ran but at low rpm so check the bolts out just a thought
Sent from my Desire HD using Tapatalk 2
Sun Sep 16, 2012 5:35 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
That is similar to what mine was doing and it ended up being a junk factory fuel pump on my 24 Honda. Got a fresh pump and good as new.
Sent using my bag phone
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Sun Sep 16, 2012 5:36 pm |
duck7878
Mon Sep 17, 2012 8:49 am |
cforstall
Thanks for the suggestions. I'll check out the carb bolts tonight.
Mon Sep 17, 2012 10:36 am |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 106 guests |
