It is currently Fri Jul 18, 2025 2:10 am
[ 6 posts ] |
QuackAndChatter
 Exhaust cleaning
I have a crossover with 20 hours on it. It has what looks like rust on it. What can i do to clean it?
Thu Sep 20, 2012 3:09 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: Exhaust cleaning
The heat does that, and you're not going to stop it from happening short of never running your motor. You can try cleaning them up some with steel wool, but it's going to happen again next time you take the boat out.
Thu Sep 20, 2012 3:37 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
Steel wool will only make it worse over time, as the carbon "leaks" to the surface of SS when it gets hot, causing the rust. Steel wool will only expose the carbon more. Just keep it sprayed with WD-40 after each trip out
_________________ 35 GTR - 1754 Extreme
Thu Sep 20, 2012 3:41 pm |
swampbilly
Joined: Fri Oct 07, 2011 6:08 pm Posts: 1054 Location: Dam-b, Texas
I used a wire wheel and die grinder on my stock exhaust then painted it with sum high temp header paint. Waitin for the paint to cure for a few days then I'll find out if it was a waste of time or not.
_________________ pd36 fpr 1754 cc rig
Thu Sep 20, 2012 4:37 pm |
CCC
Put wd40 on it. If you put a wire wheel to it every time you see rust it's not gunna last another month. You might not see it but a wire will is taking material off your already thin exhaust
Thu Sep 20, 2012 4:46 pm |
swampbilly
I didn't mean to do it everytime. Mine came in contact with salt water and then had surface rust from sittin up. Cleaned it and painted it to hopefully make it last awhile longer before buyin a new one.
Thu Sep 20, 2012 4:51 pm |
[ 6 posts ] |
Users browsing this forum: kib876, Majestic-12 [Bot] and 91 guests |
