It is currently Fri Jul 18, 2025 1:08 am
[ 4 posts ] |
duckslayer17
 compression
So i did a compression test on my brigs 35. On cylinder was 150 while the outher was 125 . So i proceeed with a leak down. It is leaking threw the intake valves. but i am not sure how how to fix this. So any help would b appreciated.
Thanks
Sun Sep 23, 2012 7:48 pm |
cb5331
 Re: compression
Best solution is to have your heads reworked and ss valves installed. If you don't want to fork out the dough for that, you can pop the heads off and lapp them in yourself. I think 50hptiller has a video on youtube, if not, there is def several on there. It is not hard to do.
Sun Sep 23, 2012 7:51 pm |
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
 Re: compression
auto parts store has valve lapping compound in a tube and a tool with suctions on it to rework yur valves. an easy job. could be carbon build up. i run marvel oil in my gas every so often to take care of the carbon build up. or just pull the heads and do it manually.
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
Sun Sep 23, 2012 9:40 pm |
duckslayer17
 Re: compression
Thanks fellas...i think im going to try and clean it. But if that dont work, then cody might have a little more work on his hands.
Mon Sep 24, 2012 12:06 pm |
[ 4 posts ] |
Users browsing this forum: kib876 and 106 guests |
