Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
 Mikuni Accelerator Pump ???
Made some adjustment to my carb because I was not getting full travel. Now when I throttle up, it will not go all the way back down to idle. it stays around 2000-2500 rpms. It's not the throttle cable as it releases all the way. Its the Accelerator pump not going all the way back down. I can push down on the pump with my thumb and it will release, but thats the only way. The 2 Adjustment screws will not fix the problem either.
Any suggestions?
_________________ WC Custom 1854
| Sat Jul 18, 2009 11:15 am |
stumpgrinder
 Re: Mikuni Accelerator Pump ???
if it wasn't doin' that before..... go back & undo whatever u did to cause that. lol
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
| Sat Jul 18, 2009 12:53 pm |
JD
Check your choke make sure its off and you hace a little slack in the line. Make sure the pump rod is not jamming in the guide thats part of the carb body. Mine froze solid.
JD
| Sat Jul 18, 2009 1:03 pm |
Full Throttle
I have a little slack in the cable. I can take the accelerator pump and push it up by hand and it will drop all the way back down. When I twist the throttle it goes all the way up, but only drops about half way down.
I ordered the drag specialties throttle and custom cable from motion pro, so i might just wait to install it to see if that is the problem.
| Sat Jul 18, 2009 2:21 pm |
stumpgrinder
exactly what "adjustments" did u make to da carb? da only time I found my mikuni not openin all da way was cuz da cable wasn't gettin pulled all da way. I'm still tryin to figure out what "adjustments" u did...
| Sat Jul 18, 2009 2:59 pm |
Full Throttle
Tightend up the cable some and straightened up the white guide wheel that the cable rides on.
It looks like I may have overtightened the bolt that hold the cable and it is kinked...... The black vinyl is all chewed up right there.
| Sat Jul 18, 2009 3:22 pm |
stumpgrinder
a kink in da cable will do it. disconnect it from da carb and see if everything works right manually without da cable.
| Sat Jul 18, 2009 3:42 pm |
Full Throttle
| Sat Jul 18, 2009 3:53 pm |
stumpgrinder
| Sat Jul 18, 2009 3:59 pm |
deadbird8
Dude- you sure are changing lots of stuff at the same time. My advice is to get it right and then introduce new variables.
I will be back in a couple of weeks and we can go run.
| Sat Jul 18, 2009 10:00 pm |
