Motor Mods -vs- Dyno HP gains info
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32814
Author:  rudyeng [ Sun Sep 30, 2012 5:40 pm ]
Post subject:  Motor Mods -vs- Dyno HP gains info
Blueprinting the Briggs Stocker - One Step at a Time
By Joey Padgett of Checkered Flag Fuels
World Karting Magazine, November, 1994
Joey Padgett and his crew at Checkered Flag Racing Fuels have always wondered how each stop of their engine blueprinting process affected the overall performance of the Briggs stock 5hp engine. Well, to satisfy their curiosity, and to educate and inform WKA members, the WKA donated a Box Stock 5hp to Padgett and crew to blueprint and dyno in a step-by-step process, carefully measuring the effect of each change along the way.
The Checkered Flag crew for this test consisted of Joey Padgett, chief engine builder, and Brandon Creedle, chief dyno operator and grunt labor. Checkered Flag has a fully equipped machine shop and their shop's talents at building Briggs 5hp engines are nationally recognized with several WKA National wins. They use a Stuska water brake dyno and have worked very hard at getting accurate and repeatabe results from their dyno.
1. Engine Break-In
The first step in preparing a race engine from the Stock 5hp Briggs out of the box (hence, box stock), was to run the engine in on the dyno for three hours at 5800 rpm. This was done, monitoring the temperature and putting the engine under a small load on the dyno. The goal was to season the block and get all the moving parts familiar with one another.
A dyno pull was made after engine break-in on the stock but now seasoned engine. A reading was made at 3600 rpm., since Briggs uses that rpm figure for establishing their 5hp rating. The engine made 5.09 horsepower at 3600 rpm, just a tad more than Briggs claims for this engine. Futher runs were made to establish the power curve of the engine in the rpm range where we expect to run the engine on the track.
RPM Torque HP*
3600 - 5.09
4750 .880 4.48
5000 .750 4.02
5250 .670 3.77
5500 .560 3.30
5750 .430 2.65
6000 .330 2.12
Average .603 3.39
*All dyno runs in this article are corrected to standard temperature, humidity and atmospheric pressure to reduce any weather related influences. Torque figures are gauge readings, and not actual corrected torque.
Modifications
The step-by-step modifications to e performed on this stock engine were the same as done to each blueprint Checkered Flag engine. The sequence of the modifications was selected to resemble what a typical racer might try if he were blueprinting the engine himself. Also, the sequence was selected to minimize the amount of teardowns and was accomplished with tearing the motor down only twice.
Exhaust Change
The stock Briggs muffler was removed and a .930 triple stage header was installed on the stock Briggs 5hp test engine. Again, the engine was running on pump gas with 21 ounces of 30W petroleum oil in the sump as per Briggs standard recommendations.
RPM Torque HP Change %Change
3600 - 5.52 0.430 8.44
4750 1.145 5.79 1.310 29.94
5000 1.060 5.65 1.630 40.55
5250 0.980 5.48 1.710 45.36
5500 0.905 5.30 2.000 60.60
5750 0.720 4.41 1.760 66.41
6000 0.640 4.09 1.970 92.92
Average 0.908 5.12 1.730 59.41
Obviously, the stock Briggs muffler was very restrictive to the exhaust flow. The huge increase in horsepower from 5000 to 6000 rpm reflects this.
2. Change to Menthanol Fuel
3600 - 6.35 0.830 15.04
4750 1.240 6.27 0.480 8.29
5000 1.120 5.96 0.310 5.49
5250 1.040 5.81 0.330 6.02
5500 0.950 5.56 0.260 4.90
5750 0.740 4.53 0.120 2.72
6000 0.650 4.15 0.006 1.47
Average 0.957 5.38 0.260 5.08
The change to menthanol fuel produced the biggest gain on the bottom end of the power curve and diminished as the RPM increased. The temperature indicated that a smaller jet may have produced more power with the rest of the motor in the stock condition.
3. Blueprinted Carb
The stock carb we had been using for the test up to this point was flowed and blueprinted and flowed again. Before the blueprinting, the carb flowed 21.03 cfm, after the blueprint job, it flowed 24.36 cfm, an increase of 16%.
3600 - 6.57 0.220 3.46
4750 1.320 6.66 0.390 6.22
5000 1.220 6.48 0.520 8.72
5250 1.080 6.02 0.210 3.61
5500 0.980 5.73 0.170 3.06
5750 0.830 5.07 0.540 11.92
6000 0.660 4.21 0.060 1.45
Average 1.015 5.70 0.320 5.95
The blueprint carb was a good change for the bottom of the power curve, but the .052" jet may have put a hole in the fuel curve as indicated by the percentage change around 5500, 5750 and at the top rpm at 6000. Further modifying this engine should take advantage of the extra rich fuel curve on the top end of this motor.
4. Deck Block and Mill Head
Now the machine work begins. Taping off all the openings, the engine was left assembled except for removing the head. The head is milled to the specs listed in the WKA tech manual. The block was decked so that the piston protruded out of the block .0035". The engine was cleaned off and the head reinstalled with a stock gasket and the bolts torqued.
3600 - 6.69 0.120 1.83
4750 1.140 7.16 0.500 7.51
5000 1.320 7.06 0.580 8.95
5250 1.220 6.85 0.830 15.45
5500 1.080 6.35 0.620 10.82
5750 0.950 5.84 0.770 15.19
6000 0.820 5.26 1.050 24.94
Average 1.130 6.42 0.720 12.63
The engine liked more compression and the re-chambering of the combustion chamber. A 12% average increase is great for just doing some minor machine work. Importantly, this increased the engine's ability to work better at the higher rpms and produced the most significant increases above 5000 rpm.
5. Porting and Valve Job
The ports were de-burred and enlarged, using information from the flow bench as previously developed by Checkered Flag. It's very easy to get the exhaust port too big, so just a general deburring and smoothing of the port was done here. Most of the port work was concentrated on the intake port.
3600 - 7.02 0.330 4.93
4750 1.520 7.73 0.570 7.96
5000 1.420 7.60 0.540 7.65
5250 1.340 7.53 0.680 9.93
5500 1.190 7.01 0.660 10.39
5750 1.100 6.77 0.930 15.92
6000 0.920 5.91 0.650 12.36
Average 1.200 7.09 0.670 10.44
Joey felt he should have just de-burred the ports and made a dyno run so we could have compared exactly what a good port job would mean as compared to a karter just de-burring his ports with a hand grinder at home. Again, this porting work is just moving the power band up the rpm scale and allowing the earlier changes on the carb and fuel to take full effect.
6. Honing Cylinder and Clearance Rings
The engine was disassembled and the block was honed out to a 0.003" oversize. The ring end gaps before honing were:
Before Hone:
Top 0.016"
2nd ring 0.009"
Oil ring 0.016"
After Hone:
Top 0.002" (using a 0.010" in a std. bore)
2nd ring 0.018" (same ring w/0.003 more gap due to hone)
Oil ring 0.090" (ring thickness ground down from 0.130 to 0.095)
Cylinder had 0.0035" clearance on the piston with .002 out of round and 0.001" taper.
After Hone: 0.0065" piston clearance, 0.000" out of round and 0.000" taper.
3600 - 7.08 0.060 0.85
4750 1.550 7.92 0.190 2.20
5000 1.480 7.96 0.360 4.74
5250 1.380 7.79 0.260 3.45
5500 1.290 7.63 0.620 8.85
5750 1.180 7.30 0.530 7.83
6000 1.060 6.84 0.930 15.74
Average 1.320 7.57 0.480 6.77
The engine picked up at the high rpm due to the decrease in ring drag and reduced internal friction. The engine runs the longer races, these lower temps will result in reducing the internal friction and engine wear.
7. Synthetic Oil
Up until now, all runs had been made using 21 oz. of 30W Petroleum oil as Briggs specifies. On this run, 14 oz. of a light synthetic oil generally used by most karts was substituted.
3600 - 7.10 0.020 0.28
4750 1.585 8.03 0.110 1.38
5000 1.505 8.03 0.070 0.88
5250 1.395 7.81 0.020 0.26
5500 1.320 7.75 0.120 1.57
5750 1.230 7.55 0.250 3.42
6000 1.120 7.17 0.330 4.82
Average 1.359 7.72 0.150 1.98
Not a huge gain here - maybe if we'd used some of the "trick" (i.e. illegal) oils here, we might have seen more gain. In fact, Checkered Flag sells some of the base substances to mix with synthetic oils to make it "hot." Their own dyno testing shows little if any real gain on the dyno.
8. Ignition Timing
The stock timing from Briggs for all previous dyno runs had been 21(. Using a #5 offset timing key, it was advanced to 28(.
3600 - 7.25 0.150 2.11
4750 1.600 8.16 0.130 1.62
5000 1.500 8.05 0.020 0.25
5250 1.430 8.06 0.150 1.90
5000 1.340 7.91 0.160 2.06
5750 1.280 7.90 0.350 4.64
6000 1.170 7.54 0.370 5.16
Average 1.387 7.94 0.220 2.85
Again, just small gains with the timing advanced, all under a 5% gain. A Limited Modified engine with its more radical cam timing will show more results from the advanced ignition timing.
9. Camshaft Change
The stock Briggs cam was replaced with the ZX3 cam from Checkered Flag. This specifically profiled cam works the best in all their stock class engine blueprints.
3600 - 6.88 0.370 -5.10
4750 1.670 8.52 0.360 4.41
5000 1.620 8.70 0.650 8.07
5250 1.560 8.79 0.730 9.06
5500 1.460 8.62 0.710 8.98
5750 1.380 8.52 0.620 7.85
6000 1.310 8.44 0.900 11.19
Average 1.500 8.60 0.660 8.31
The engine initially lost power at 3600 rpm with the cam change because that rpm was out of the power curve for this cam profile. This cam provided a good power increase from 5000 to 5500 and another great power surge at the very top rpm of 6000.
Summary
The best horsepower number for this test engine came on the final run at 5250 rpm where it made 8.79 horsepower. Joey says the average engine out of their shop is 8.75 to 8.9 horsepower, so our test engine is right on target. The best WKA legal engine they have seen on their dyno is just over 9 hp!
Reviewing the step-by-step blueprinting process:
Modification Avg. HP Peak HP Gain
Exhaust Change 5.12 5.79 59%
Menthanol Fuel 5.38 6.27 5%
Blueprint Carb 5.70 6.66 6%
Deck Block, head 6.42 7.16 13%
Port Work 7.09 7.73 10%
Hone & Clearance 7.57 7.96 7%
Synthetic Oil 7.72 8.03 2%
Reset Timing 7.94 8.16 3%
Change Camshaft 8.60 8.79 8%
Total Blueprint 170%
Your results may vary according to how your dyno is set up and operated. It is very evident that the biggest gain was in the exhaust pipe and in the machine work and porting. The WKA has sought to restrict what can be gained from other things like camshafts and carbs, trying to even the playing field for all racers.
A blueprinted engine from Checkered Flag just like the one we have here would cost about $600. Just the machine work, decking the block ($20), porting the cylinder ($50) and milling the head ($10) would cost $80 and are the items the average karter would not have the equipment to do in his garage at home. But then, the experience and expertise of shops like Checkered Flag are sometimes worth the price of buying the total engine from them.
Author:  duckduckboom [ Sun Sep 30, 2012 8:49 pm ]
Post subject:  Re: Motor Mods -vs- Dyno HP gains info
This is a pretty cool thread thanks for posting it.
If you ever get a bit froggy, feel free to do this with a big block Briggs. I would really like to see that
