exhaust problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32851 |
Author: | jakecologne [ Mon Oct 01, 2012 7:46 pm ] |
Post subject: | exhaust problem |
I have an EVT exhaust. when running sounds like I have a leakin sound almost. all the gaskets are good. no cracks in exhaust. it doesn't have to true sound of the exhaust |
Author: | jakecologne [ Tue Oct 02, 2012 5:25 am ] |
Post subject: | Re: exhaust problem |
ttt |
Author: | JLACOUR [ Tue Oct 02, 2012 6:45 am ] |
Author: | Beadlejuicejr [ Tue Oct 02, 2012 8:22 am ] |
Just cause a exhaust gasket looks good doesn't mean it's dealing double them up and see if that helps I have to do that with my MM cause the flanges are a lil warped |
Author: | jakecologne [ Tue Oct 02, 2012 9:09 am ] |
it doesn't have baffles. it sounds like the noise is coming out one of the heads. I heard my evt and another evt without baffles side by side and can tell mine doesn't have the true sound |
Author: | deltaduckmaster [ Tue Oct 02, 2012 10:21 am ] |
Maybe the weld to the flange is broke. The weld is on the inside. |
Author: | jakecologne [ Tue Oct 02, 2012 10:32 am ] |
this is 2nd exhaust that did that for me so I'm starting to think its something with the engine rather than the exhaust |
Author: | deltaduckmaster [ Tue Oct 02, 2012 10:40 am ] |
Light material with heat. Shut is gonna break |
Author: | jakecologne [ Tue Oct 02, 2012 4:48 pm ] |
got home an took at look at it the noise sounds like its comin from the engine itself not the exhaust |
Author: | Team Camo [ Tue Oct 02, 2012 5:00 pm ] |
Pull the cover & check the rockers & push rods. Might just need set valve lash. |
Author: | jakecologne [ Tue Oct 02, 2012 5:59 pm ] |
that would make it sound different ? |
Author: | Team Camo [ Tue Oct 02, 2012 6:31 pm ] |
Sorry, just reread, thought you said it was making knocking sound. Nevermind, probably a leaking slip flange. |
Author: | jakecologne [ Tue Oct 02, 2012 6:58 pm ] |
my previous crossover exhaust that didn't have slip flanges made the same noise |
Author: | Beadlejuicejr [ Tue Oct 02, 2012 7:25 pm ] |
Pull off your exhaust check the welds on the inside the flange of they are craked. Put it back on with double gaskets and see if it continues. Start checking stuff only way you gonna figure it out |
Author: | deadbird8 [ Thu Oct 04, 2012 5:23 am ] |
Author: | jakecologne [ Thu Oct 04, 2012 5:31 pm ] |
new gaskets, no cracks in flanges. still makin same noise |
Author: | Beadlejuicejr [ Thu Oct 04, 2012 5:35 pm ] |
Have you checked your valves. Do you have any mods on your motor |
Author: | jakecologne [ Thu Oct 04, 2012 5:43 pm ] |
carb an exhaust. do u think that my valves just need to reset ? |
Author: | Beadlejuicejr [ Thu Oct 04, 2012 6:01 pm ] |
Check them for sure and see. I was thinking check your governor block make sure it's still in the right place and didn't move or anything |
Author: | jakecologne [ Thu Oct 04, 2012 6:01 pm ] |
what could the gov block cause |
Author: | Beadlejuicejr [ Thu Oct 04, 2012 6:10 pm ] |
Your governor shaft could just be doing what it wants |
Author: | jakecologne [ Thu Oct 04, 2012 6:12 pm ] |
causing the exhaust to sound different ? |
Author: | mizzippi jb [ Thu Oct 04, 2012 6:36 pm ] |
Author: | pokey79 [ Thu Oct 04, 2012 6:43 pm ] |
crank it up and use ur hand to see if u can feel air coming from somewhere |
Author: | jakecologne [ Thu Oct 04, 2012 7:04 pm ] |
I'm gettin my valves an what not checked tomorrow |
Author: | take'emgator [ Thu Oct 04, 2012 8:12 pm ] |
could have a small head gasket leak, is it coming from both sides or just one? |
Author: | jakecologne [ Thu Oct 04, 2012 8:34 pm ] |
sounds like just one side. there is no oil any where that shows a leak. the valves haven't been checked in a couple hundred hours |
Author: | Woodiebuster [ Thu Oct 04, 2012 8:40 pm ] |
Pour just a little Auto Tranny fluid down the carb, itll smoke like a Mofo and you will be able to see any leaks. |
Author: | take'emgator [ Thu Oct 04, 2012 8:45 pm ] |
Pressure up the cylinder like you are doing a leak down test and see if you have any leaks around the head gaskets just to eliminate that, check valve springs to make sure your didn't break one, that would jack with a valve and make the motor sound weird and run different, make sure all your valve train is still infully intact. |
Author: | jakecologne [ Thu Oct 04, 2012 8:48 pm ] |
the motor seems to be running fine but I will get all the valves an springs checked out tomorrow |
Author: | jakecologne [ Thu Oct 04, 2012 8:49 pm ] |
if it wasn't for the shitty air sound coming out my exhaust it would be all good |
Author: | richard nagon [ Thu Oct 04, 2012 8:50 pm ] |
well at two hundred hours i think u just found a starting point. valves should be cked at every 50 hrs. looks like takem has a new best friend soon to be customer. do a leak down. |
Author: | take'emgator [ Thu Oct 04, 2012 8:51 pm ] |
do you see any blackness arund the exhaust flanges like on the cylinder head, eliminate the exhaust gasket by changing them and putting 2 of them. Just some pointers, to help you along, casue trust me everyone on this page is gonna wanna know what it is lol Right on Naggon, always chack valves from time to time, you can ruin a cam quick if one of them is out of wack and it don't take much |
Author: | jakecologne [ Thu Oct 04, 2012 8:52 pm ] |
yea ill get all that checked tomorrow an get back to y'all. thanks for the help so far fellas |
Author: | jakecologne [ Thu Oct 04, 2012 8:54 pm ] |
there is black on the heads where u can tell it was leaking. I changed gaskets today to eliminate that |
Author: | jakecologne [ Fri Oct 05, 2012 5:46 pm ] |
valves reset an it sounds perfect |
Author: | Team Camo [ Fri Oct 05, 2012 5:57 pm ] |
Amazing what a lil maintenance will do, huh? ![]() Glad you finally got it lined out. |
Author: | jakecologne [ Fri Oct 05, 2012 6:09 pm ] |
haha yea |
