valve lash adjustment cdi 35 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=32985 |
Author: | SwampSlut [ Sat Oct 06, 2012 4:35 pm ] |
Post subject: | valve lash adjustment cdi 35 |
looking to adjust my valve lash cant seem to find anything other than questions about it in the search anyone know who has ever posted a video on this or can help me narrow the search... ive noticed the search function is pretty vague. when you try and get a lil more specific it says no results. any help would be appreciated. |
Author: | Team Camo [ Sat Oct 06, 2012 4:44 pm ] |
Post subject: | Re: valve lash adjustment cdi 35 |
Couple different ways to do it. I go to 1/4" past tdc on compression stroke & set both valves at .005, then do same on other cylinder. Do it with engine cold. |
Author: | take'emgator [ Sat Oct 06, 2012 10:55 pm ] |
DO you know what top dead center is, cause if not i would suggest taking it somewhere, setting lash wrong can have some bad consiquences. |
Author: | pooldoo73 [ Tue Oct 09, 2012 9:45 am ] |
Dam, all this time I thought tdc meant to da corner. |
Author: | Will [ Tue Oct 09, 2012 9:53 am ] |
Cody's way to set valves is much more easy and less chances of messing anything up in the cylinder or breaking off a piece of wood in there or whatever other horror stories people have. |
Author: | take'emgator [ Tue Oct 09, 2012 10:02 am ] |
i got a video hang on, setting lash http://www.youtube.com/watch?v=Iko2iztt ... plpp_video |
Author: | Will [ Tue Oct 09, 2012 10:12 am ] |
Author: | take'emgator [ Tue Oct 09, 2012 11:46 am ] |
oh |
Author: | bubba777 [ Tue Oct 09, 2012 6:42 pm ] |
Author: | Will [ Wed Oct 10, 2012 4:54 am ] |
Author: | SwampSlut [ Wed Oct 10, 2012 9:47 am ] |
Author: | richard nagon [ Wed Oct 10, 2012 8:36 pm ] |
good advice on the lash setting tiller. the bump on the intake side can be felt by holding the intake side push rod and u can still do it ur way. that bump can also cause a inaccurate compression reading if ur not spinning the engine fast enough. some builders that use a bump in the cam for starting ck the compression by spinning the motor backwards. make sense |
Author: | richard nagon [ Wed Oct 10, 2012 9:06 pm ] |
it made no sense to me either. |
