Buddy
Joined: Mon Aug 06, 2012 9:06 am Posts: 579 Location: Tallahasse, FL
 Gutting a Stock PD Exhaust
I Just finished removing the baffles out of a stock PD exhaust. It involved cutting off both end caps, and a lot of grinding on the tack welds. I also replaced the stock outlet with a larger one. I used a piece of 2" sch 10 304 stainless pipe that I got off online metals. I tigged it all back together with 3/32" 309 tig wire.
Still awaiting a test run to hear what it sounds like.
_________________ 1754 XSeries Kawi Powered PRODRIVE ...
Sun Oct 07, 2012 11:00 am |
gatorkiller1967
 Re: Gutting a Stock PD Exhaust
They sound great!
Sun Oct 07, 2012 1:00 pm |
Buddy
I hope so that was a lot of work to sound like shit.
Sun Oct 07, 2012 3:45 pm |
gatorkiller1967
I did mine with a chop saw. Only took a few minutes. Seems to have more power after I gutted it
Mon Oct 08, 2012 11:25 am |
MudBuddy77
Joined: Mon Oct 03, 2011 5:56 pm Posts: 298 Location: Caddo lake
Could you mig weld that back up or how did y'all do it
Mon Oct 08, 2012 1:47 pm |
gatorkiller1967
Yes. Mig weld
Mon Oct 08, 2012 2:51 pm |
Buddy
I Tig Welded mine. I think the muffler is of low grade stainless. As long as your mig welder has good heat control it should be fine. If you tig weld it I wouldn't bother purging the back side because of the exhaust carbon it will "sugar" anyways.
Mon Oct 08, 2012 4:08 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
its not stainless... a magnet will stick to it..
mine isnt much louder than stock and I lost rpm with it vs my evt
_________________ I gave up mud motors
Mon Oct 08, 2012 6:25 pm |
Buddy
I agree. I was told it was stainless, and my magnetic level stuck to it. The muffler could be stainless with higher carbon levels than nickel. But More than likely just carbon steel.
It is a little disappointing to hear yours wasn't louder and that you lost rpms. I had heard that this is the way to go to imporve flow and performance.
Mon Oct 08, 2012 6:42 pm |
T-Bubba
its better than stock no doubt
but not as good as going evt or mm
Mon Oct 08, 2012 6:58 pm |
