It is currently Sat Jul 19, 2025 6:22 am
Reply to topic  [ 7 posts ]
 Building a motor
Post Building a motor
Recently got hooked up with a guy with a water jet machine a d he's cutting pieces to build a motor all except for shaft. Here's my problem I have a 18.5 Briggs vertical shaft very strong motor but I like the simplicity of having a horizontal shaft with a poly chain. Anyone out there ever turn vert-horiz successfully or built a vertical shaft motor at home don't really want to go out and buy a 5-6 thousand dollar unit when I can built myself just wanting to know if I can convert motor or have to use the horizontal I have it's only a 13hp
Wed Oct 17, 2012 11:47 am
Post Re: Building a motor
had a guy on here selling a lower unit off a prodrive. from what i read, you would need a tower bushing setup, clutch and some other things, but its a start.
Wed Oct 17, 2012 12:22 pm
^that is basically just the gear housing, need a whole lot more than some bushings and a clutch...
Wed Oct 17, 2012 12:31 pm
yeah, wasn't sure. But its a start if he's up to machining parts.
Wed Oct 17, 2012 1:08 pm
What's is his info up for anything if reasonable
Wed Oct 17, 2012 1:14 pm
By the time you machined/cast all those parts, you could buy a whole pd.
Wed Oct 17, 2012 1:19 pm
What about predator 420 what is y'all's take on it and it would be belt driven with a pulley drive what prop size would be good on a 15-42
Wed Oct 17, 2012 8:55 pm
Users browsing this forum: JphIII and 88 guests
