Building a motor
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=33349
Author:  Jdog3o [ Wed Oct 17, 2012 11:47 am ]
Post subject:  Building a motor
Recently got hooked up with a guy with a water jet machine a d he's cutting pieces to build a motor all except for shaft. Here's my problem I have a 18.5 Briggs vertical shaft very strong motor but I like the simplicity of having a horizontal shaft with a poly chain. Anyone out there ever turn vert-horiz successfully or built a vertical shaft motor at home don't really want to go out and buy a 5-6 thousand dollar unit when I can built myself just wanting to know if I can convert motor or have to use the horizontal I have it's only a 13hp
Author:  banded-mallard [ Wed Oct 17, 2012 12:22 pm ]
Post subject:  Re: Building a motor
had a guy on here selling a lower unit off a prodrive. from what i read, you would need a tower bushing setup, clutch and some other things, but its a start.
Author:  cb5331 [ Wed Oct 17, 2012 12:31 pm ]
^that is basically just the gear housing, need a whole lot more than some bushings and a clutch...
Author:  banded-mallard [ Wed Oct 17, 2012 1:08 pm ]
yeah, wasn't sure. But its a start if he's up to machining parts.
Author:  Jdog3o [ Wed Oct 17, 2012 1:14 pm ]
What's is his info up for anything if reasonable
Author:  cb5331 [ Wed Oct 17, 2012 1:19 pm ]
By the time you machined/cast all those parts, you could buy a whole pd.
Author:  Jdog3o [ Wed Oct 17, 2012 8:55 pm ]
What about predator 420 what is y'all's take on it and it would be belt driven with a pulley drive what prop size would be good on a 15-42
