Kill Switch Doesn't Work! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3362 |
Author: | duckbill [ Wed Jul 22, 2009 4:58 pm ] |
Post subject: | Kill Switch Doesn't Work! |
I have a 24 HP Honda Beavertail LT motor. My kill switch doesn't work, but all of the wires seem to be connected properly. The motor runs, but when I disconnect the kill switch, it keeps on running. Any thoughts on where to begin trouble shooting the issue? |
Author: | stumpgrinder [ Wed Jul 22, 2009 5:02 pm ] |
Post subject: | Re: Kill Switch Doesn't Work! |
if u have an ohm meter check continuity across da switch to make sure it's good, if it's good ur wiring ain't right. |
Author: | sea-n-spots [ Wed Jul 22, 2009 5:03 pm ] |
Author: | schrieverboy [ Wed Jul 22, 2009 5:09 pm ] |
def. replace da switch if u say your wiring is good dats ya best chance. how old is dat kill switch |
Author: | duckbill [ Wed Jul 22, 2009 10:40 pm ] |
kill switch is about 8 years old |
Author: | white1 [ Thu Jul 23, 2009 5:20 am ] |
The kill switch has normally open contacts I. It. If you remove the wires, nothing is going to happen. I had one go out on my last motor, it was less than a year old. If you want to make sure your wiring is right just short the wires together. That would simulate you operating the switch and should kill the engine |
