It is currently Fri Mar 20, 2026 12:46 pm
[ 4 posts ] |
XD set up question regarding trim
Oglebuck
I notice on my 37XD at the transom it has a bolt with 5 different settings to set up motor angle. What is the correct way to set that up. When I’m running, planned out and trimmed all the way up my prop is 6-8” under the water surface. Is that correct or should I be able to trim all the way up and prop be out or on top of water surface
| Tue Nov 06, 2018 9:31 am |
Will C
 Re: XD set up question regarding trim
You want the ability to overtrim some. Move bolt up and test it
| Tue Nov 06, 2018 10:51 am |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
Play with bolt position. On my boat, I got best performance on the top hole.
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
| Wed Nov 07, 2018 7:24 am |
Oglebuck
Thanks. I move it up one hole to top hole. Now I can get better hole shot and plain a lot quicker with less trim adjustment and I can trim all the way up until the prop is about half out of water. I think I’ll continue running it in that position.
| Wed Nov 07, 2018 8:47 am |
[ 4 posts ] |
