| Rev limiter. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3449 |
| Author: | darrel from meraux [ Sun Jul 26, 2009 8:34 pm ] |
| Post subject: | Rev limiter. |
i got the evt rev limiter and i have my black wire on the rev limiter grounded to the boat. my red on the rev limiter is tapped into the red wire coming off my key switch. and the green wire connects to the black wire coming from my coils. Now.. my problem is the motor will run for a minute and kill then wont restart, well if i disconnect the green wire on the rev limiter it'll run good all day. Watchall think my prob is? |
| Author: | PaulDarensbourg [ Sun Jul 26, 2009 8:46 pm ] |
| Post subject: | Re: Rev limiter. |
your rev limiter is broke. Take it off and run the motor without, |
| Author: | grrifles [ Mon Jul 27, 2009 8:03 am ] |
Try grounding the rev limiter to the engine. Do you have the battery grounded to the boat? if not you are not getting a good ground. |
| Author: | TXSHOCKWAVE [ Fri Jul 31, 2009 7:50 pm ] |
DO NOT GROUND THE BOAT TO THE BATTERY. THAT WILL CAUSE ELECTROLYSIS. |
| Author: | darrel from meraux [ Fri Jul 31, 2009 7:57 pm ] |
dident think anyone was interested so i dident update. well, i did fix the problem and it's runnin great now. my problem was i had the power wire hooked into the red wire on the keyswitch instead of on the grey fuel shutoff wire. and no my batt's not grounded out to the boat. |
