| motor wont start http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3689 |
| Author: | forever draggin [ Tue Aug 04, 2009 6:12 pm ] |
| Post subject: | motor wont start |
battery is good trim works, and i can hear clutch engage and disengage when the ign is on and the gear switch is flipped. turn key to start motor and nothing happens jump positive and negative on starter soilonoid with screwdriver and motor spins out of ideas, think maybe the ignition is bad? |
| Author: | schrieverboy [ Tue Aug 04, 2009 6:15 pm ] |
| Post subject: | Re: motor wont start |
how does your wiring look??? n e breaks or freys n e where |
| Author: | shallow water master [ Tue Aug 04, 2009 6:18 pm ] |
do u have gas in it |
| Author: | shallow water master [ Tue Aug 04, 2009 6:19 pm ] |
| Author: | schrieverboy [ Tue Aug 04, 2009 6:21 pm ] |
| Author: | muddiejeep [ Tue Aug 04, 2009 6:24 pm ] |
kill switch? |
| Author: | schrieverboy [ Tue Aug 04, 2009 6:27 pm ] |
motor shouldnt turn at all wit no kill switch |
| Author: | shallow water master [ Tue Aug 04, 2009 6:31 pm ] |
| Author: | shallow water master [ Tue Aug 04, 2009 6:33 pm ] |
it could be the stupid ass fuel cut off on the carb. they go bad and u can start it cuz it ect. ran and stop all fuel |
| Author: | muddiejeep [ Tue Aug 04, 2009 6:34 pm ] |
| Author: | muddiejeep [ Tue Aug 04, 2009 6:35 pm ] |
what if the rev. limiter went out? |
| Author: | schrieverboy [ Tue Aug 04, 2009 6:37 pm ] |
key switch could be out |
| Author: | shallow water master [ Tue Aug 04, 2009 6:38 pm ] |
| Author: | muddiejeep [ Tue Aug 04, 2009 6:38 pm ] |
loose wire on key switch. |
| Author: | forever draggin [ Tue Aug 04, 2009 6:59 pm ] |
dont think the flywheel key is sheared because if u jump it at the soilonoid itll run. checked all fuses and connectins- they look fine. from what i see wiring looks great ign switch could be out, but i doubt it because when u turn it half way u can work trim and clutch it does have gas, but even if it didnt it would still spin over kill switch is on dont know how to bypass the rev limitor to eliminate that as the problem |
| Author: | shallow water master [ Tue Aug 04, 2009 7:01 pm ] |
| Author: | schrieverboy [ Tue Aug 04, 2009 7:03 pm ] |
check for a voltage drop when u go to turn it over |
| Author: | muddiejeep [ Tue Aug 04, 2009 7:04 pm ] |
I think you cut a green wire |
| Author: | forever draggin [ Tue Aug 04, 2009 7:16 pm ] |
i stated that when jumping the soilonoid that the motor runs, it doesnt run, it just spins but acts like it doest get either fuel or fire |
| Author: | schrieverboy [ Tue Aug 04, 2009 7:21 pm ] |
no fouled plugs huh?? |
| Author: | SwampSnyper [ Tue Aug 04, 2009 7:26 pm ] |
Either the wires came loose on the back of the kill switch or ignition, but I'm willing to bet rev limiter. I think just cutting the green will work it, but I would cut them all. Bet it starts up then. |
| Author: | backwaterballer [ Tue Aug 04, 2009 7:44 pm ] |
Chech the ground for your coils won't gave fire if it has a bad connection nut will still spin |
| Author: | PaulDarensbourg [ Tue Aug 04, 2009 7:45 pm ] |
Wo wo wo, don't start cutting shit, call me. Pretty sure I know what the problem is. |
| Author: | Gigafowl [ Tue Aug 04, 2009 7:49 pm ] |
Luke 6:39 |
| Author: | PaulDarensbourg [ Tue Aug 04, 2009 8:06 pm ] |
| Author: | craig [ Tue Aug 04, 2009 8:11 pm ] |
| Author: | PaulDarensbourg [ Tue Aug 04, 2009 8:14 pm ] |
It's fixed, just a wire connector. |
| Author: | forever draggin [ Tue Aug 04, 2009 9:26 pm ] |
yeah had a bad wire crimp on back of the starter silnoid. everything is good to go |
| Author: | schrieverboy [ Wed Aug 05, 2009 6:34 am ] |
good deal |
| Author: | coondik [ Wed Aug 05, 2009 6:45 am ] |
jiggle, jiggle - vroom. vroom |
| Author: | deadbird8 [ Wed Aug 05, 2009 8:34 am ] |
| Author: | LA OUTLAW [ Wed Aug 05, 2009 7:06 pm ] |
| Author: | schrieverboy [ Wed Aug 05, 2009 7:40 pm ] |
maybe some of us just had some sh!tty wiring before |
| Author: | bayouboy [ Wed Aug 05, 2009 7:50 pm ] |
| Author: | schrieverboy [ Wed Aug 05, 2009 7:53 pm ] |
n e thing is possible.... its hard to diagnose stuff when you are not there troubleshooting yourself... but you have to start wit da simplist most common sh!t first |
| Author: | Mitschke [ Wed Aug 05, 2009 7:56 pm ] |
| Author: | schrieverboy [ Wed Aug 05, 2009 8:00 pm ] |
nothing in dat situation... i thought it was funny at da time.... ass |
| Author: | bayouboy [ Wed Aug 05, 2009 8:36 pm ] |
AHhhhhooooooooooo! He said your an ass Mitschke! you gonna take dat? lol |
| Author: | River [ Mon Aug 10, 2009 8:57 am ] |
Holy Crap, I guess I missed this Gem. |
| Author: | POKER1 [ Mon Aug 10, 2009 9:50 am ] |
