It is currently Tue Dec 16, 2025 10:37 am
Reply to topic  [ 6 posts ]
 Gtr 35 timing keys?
Post Gtr 35 timing keys?
Has anyone tried changing out the timing keys to advance the timing. I have a stock motor and was told adding the exhaust and changing the keys would make a noticable difference. Any info would help
Tue Aug 04, 2009 6:20 am
Post Re: Gtr 35 timing keys?
Advancing the timing is supposed to give you a little better throttle response. Some people say they see no difference at all. If you want to try it you can buy the advance timing keys thru EVT for about 5 bucks.
Tue Aug 04, 2009 6:58 am
I tried it on my 35 and didn't see a difference but others have as Craig posted. I guess its dependent on the motor.
Tue Aug 04, 2009 7:37 am
When I talked to those EVT boys they told me that I would notice gains in the low end and mid range but not so much on the top end.
Tue Aug 04, 2009 8:01 am
Someone posted this before- really explains well how the timing works on the Briggs and what the timing key is doing.
It says you give up low end as you advance.
Tue Aug 04, 2009 8:42 am
That's a good article DB8.
It seems that alot of things you adjust or replace on the engine, effects something else down the line.
Sat Aug 08, 2009 6:42 am
