It is currently Mon Feb 02, 2026 8:22 am
Reply to topic  [ 17 posts ]
 oil filter leak
Post oil filter leak
cant stop my oil filter from leaking. any of yall had the same problem? its not much but just trying to prvent it. thanks
20x44 Charles Leonard Bateau 35GTRR
Tue Aug 04, 2009 8:11 am
Profile YIM
Post Re: oil filter leak
Change it.
The gasket on the filter may be bad.
Tue Aug 04, 2009 8:13 am
x2 they are cheap...
1754 GT EXTREME 37EFI
Tue Aug 04, 2009 8:26 am
this one is brand new and my first one did the same thing. i might have to put a wrench on it.
Tue Aug 04, 2009 9:00 am
Profile YIM
Before you install the filter rub a small amount of oil on both sides of the gasket then stick it on hand tight...It should not leak after that...
Tue Aug 04, 2009 9:09 am
Pro Drive m'fers
Tue Aug 04, 2009 7:48 pm
Tue Aug 04, 2009 8:00 pm
Pro Drive m'fers
Tue Aug 04, 2009 8:01 pm
make sure the sealing surface of the filter head is smooth and true. If its machined wrong it may not seal. Thats the only thing Ive seen that would make it leak besides a bed filter seal.
BUCK OFAMA
Tue Aug 04, 2009 8:05 pm
Tue Aug 04, 2009 8:10 pm
:roll: Remember that post whenever you call me with questions :lol:
Pro Drive m'fers
Tue Aug 04, 2009 8:28 pm
:lol: :lol: :lol: :lol: :lol: Somebody's gettin fired up!!! lol
Tue Aug 04, 2009 8:31 pm
Make sure it's clean and machined properly like big said. Also make sure your leak is not coming from loose oil cooler lines. One more thing could be the old filter gasket is stuck on there but I don't think anyone is dumb enough to miss that on a mudmotor.
Tue Aug 04, 2009 8:35 pm
Duct tape!!!!!!
Wed Aug 05, 2009 10:46 am
Wed Aug 05, 2009 3:51 pm
Wed Aug 05, 2009 3:52 pm
thanks
Fri Aug 07, 2009 1:34 pm
Profile YIM
