| White Smoke? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=3771 |
| Author: | menace21 [ Fri Aug 07, 2009 3:45 pm ] |
| Post subject: | White Smoke? |
i have a 27 kohler and when i squeeze the throttle i get a huge cloud of white smoke. Anyone have any ideas? |
| Author: | backwaterballer [ Fri Aug 07, 2009 9:12 pm ] |
| Post subject: | Re: White Smoke? |
White smoke usually means your burning oil if I'm not mistakin |
| Author: | forever draggin [ Sat Aug 08, 2009 11:19 am ] |
| Author: | remi19 [ Sat Aug 08, 2009 5:28 pm ] |
had the same issue, seals where bad, burning oil. ended up having to get a new engine |
| Author: | quackconsumer [ Sat Aug 08, 2009 6:00 pm ] |
pour a little kerosene in da caborator if you really want to see white smoke |
| Author: | deadbird8 [ Sun Aug 09, 2009 4:44 am ] |
Maybe you have the Cheech and Chong edition? White smoke isn't good. |
| Author: | bjg [ Mon Aug 10, 2009 7:18 pm ] |
blue smoke should be oil. is it very white or does it have a lil blueish color. how many hours is on the engine? |
| Author: | River [ Tue Aug 11, 2009 7:39 am ] |
Could be a head gasket sucking coolant into the cylinder and burning it. |
| Author: | coastal [ Tue Aug 11, 2009 7:53 am ] |
| Author: | MaXXis85 [ Tue Aug 11, 2009 8:26 am ] |
White smoke is usually coolant entering the combustion chamber on a liquid cooled engine. I had my New motor blow white smoke a couple times and it never happend again, but it had a bluish tint to it aswell. Its fine now. Maybe sniff the exhaust somewhat to figure out if it is oil entering the conbustion chamber. Rings off the top of my head will let oil in the chamber. Do these engines have a vent from the crankcase to the intake and it can be letting oil in the chamer? |
| Author: | bjg [ Tue Aug 11, 2009 9:54 pm ] |
vent it does. That is a possibilty. |
| Author: | Saizon [ Wed Aug 12, 2009 8:25 pm ] |
I am no expert by any means but I am confused......just where is that coolant coming from? Is it in the air running across your air cooled motor or did you hook up a radiator? |
| Author: | schrieverboy [ Wed Aug 12, 2009 9:07 pm ] |
blue=oil white=usually bad air/fuel ratio might be dumpn too much fuel |
| Author: | Thelizard007 [ Thu Aug 13, 2009 12:36 am ] |
do you leave the gas tank in the boat out side? if so change the gas could have water in it that with make it about blow white smoke |
| Author: | DeathMetalDukk [ Wed Aug 19, 2009 7:46 pm ] |
| Author: | backwaterballer [ Wed Aug 19, 2009 8:15 pm ] |
If you were dumping to much fuel in it would be black smoke. White would be it's running lean. Blueish white smoke is oil. My boat was black smoking when my carb needed adjusting |
