| 2010 35hp cdi not charging http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=37857 |
| Author: | jakecologne [ Wed Feb 20, 2013 11:28 am ] |
| Post subject: | 2010 35hp cdi not charging |
my 2010 gtr is not charging a battery what should I look into first |
| Author: | Jamie B. [ Wed Feb 20, 2013 11:29 am ] |
| Post subject: | Re: 2010 35hp cdi not charging |
| Author: | Jamie B. [ Wed Feb 20, 2013 11:31 am ] |
your voltage regulator on the side of your motor, check it with a voltage meter to see what voltage it is putting out. |
| Author: | forever draggin [ Wed Feb 20, 2013 3:11 pm ] |
Check ur battery 1st |
| Author: | deadbird8 [ Wed Feb 20, 2013 9:10 pm ] |
Check the red wire from the VR with a voltmeter- should be putting out 12V at idle and up to 14.4 at ~3500 RPM. |
| Author: | jakecologne [ Sun Feb 24, 2013 12:10 pm ] |
red wire is not reading anything on a voltage meter |
| Author: | deadbird8 [ Sun Feb 24, 2013 4:47 pm ] |
Check the yellow wires from the stator for AC volts on the other side of the voltage regulator, if there is voltage there, its the regulator needing to be replaced. |
| Author: | jakecologne [ Wed Jun 05, 2013 7:44 pm ] |
put a voltage meter on it today and it's not reading anything from the red wire or the plug that comes from the fly wheel |
| Author: | Prodigy [ Wed Jun 05, 2013 8:47 pm ] |
Have u ever crossed the pos and neg wires on your battery? This will toast your regulator if u have.... |
| Author: | jakecologne [ Thu Jun 06, 2013 5:27 am ] |
no I have not |
