It is currently Wed Sep 17, 2025 9:21 pm
Reply to topic  [ 20 posts ]
 PD 36 surging
Post PD 36 surging
Hope it's OK to post this on this forum. Yesterday, while running my PD, the engine started surging at high RPMs(only above 3800). Motor was trimmed where I normally run it and it's never done this before as long as I've had a load on it. Only has about 50 hours on it. Plan to call KP tomorrow but maybe it's something stupid that I can check first.
1860 Prodigy
Sun Aug 02, 2009 8:14 am
Post Re: PD 36 surging
Sounds like ya sucked up some bugturd in the carb. Surges when it runs out of fuel, then chokes itself to stay goin, or at least that's what mine was doing.
Put yer face in the myrtles.
Sun Aug 02, 2009 9:01 am
If you have a primer bulb on it, pump it when it starts happening and see if its fuel starvation. (i.e. only happens at high RPM)
Sun Aug 02, 2009 10:29 am
I'll try that. If that temporarily solves the problem, what's the best fix?
1860 Prodigy
Sun Aug 02, 2009 2:02 pm
xgen just had it happen and ended up needing a 2-3 psi lift pump
THE, FIRST and ONLY MMT Member of the Year!
Sun Aug 02, 2009 3:06 pm
Sun Aug 02, 2009 3:30 pm
1860 Prodigy
Sun Aug 02, 2009 4:14 pm
I was being told it was bad engineering (Briggs), vapor lock of some sort :?: , some need the xtra pump some don't............all I do know is that the pump fixed it and it is now running like a champ...............call PD they have the pumps ya need if ya need it...............check all your lines and tank connections also, could be a small air leak...........
If I can't Break it, it can't be Broke.............................
Sun Aug 02, 2009 6:03 pm
Sun Aug 02, 2009 6:44 pm
Really? I've run it in warm weather before without issues.
1860 Prodigy
Sun Aug 02, 2009 9:07 pm
if u put on a vacume fuel pump instead of the pos cam driven stock pump u will solve the problem without having to deal wif a elec fuel pump. :)
Sun Aug 02, 2009 9:25 pm
1860 Prodigy
Mon Aug 03, 2009 7:43 am
Get the e-pump and get rid of the priming bulb.....problem solved
1754 GT EXTREME 37EFI
Mon Aug 03, 2009 10:12 am
Mon Aug 03, 2009 10:27 am
Tue Aug 04, 2009 8:25 pm
Git while the gitn's good...
Wed Aug 05, 2009 11:53 am
http://www.mikuni.com/fs-carburetor.html
DA is this what you where talking about??????
Wed Aug 05, 2009 3:40 pm
briggs has alot of problems wit der coils(this is comming from a briggs mec.)
when u run it for a long tiime the coil begins to heat up and stops thrown fire like it should.. itll start running like sh!t and ya rpms willl drop like it aint got fuel.. they can actually troubleshoot the coil n see if thats ya problem
1648 w/ a 36 pd fpr on dat biatch
G-14 CLASSIFIED SKIFF ON DA WAY!!
Never try to educate someone who resists knowledge at all costs.
Wed Aug 05, 2009 3:59 pm
Just another 2 cents +/- a cent. I had this problem with my PD 36. Switched to all straight fittings,good hose, good pumpbulb,good filter,good connections and clamps,no kinked hoses. Turns out, I have one of those high dollar metal fuel tanks, the kind you can run accross if a snake was to drop off in the boat,AGAIN. :o Anyhow, when I twisted the vent open(counter clockwise)I was turning it to far counterclockwise,which would choke the vent,just as if I close it(clockwise).TURN VENT COUNTERCLOCKWISE HALFWAY FOR FULL VENT, at least on the metal tanks. :roll: Runs fine now.
17x48 EXCELL/36PD
Sun Aug 16, 2009 12:22 am
I changed an inline filter out once and had nothing but problems till I put a second filter on. I had bought 2. Something was wrong with a brand new filter. These things can be finicky for sure.
18x48 Charles Leonard / 36PD
Sun Aug 16, 2009 1:23 am
