It is currently Sun Apr 12, 2026 8:54 am
Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
 Case gasket
Post Case gasket
Is there a good fix yet?
Mon Aug 17, 2009 9:06 pm
Post Re: Case gasket
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Mon Aug 17, 2009 10:28 pm
Open motor, remove old gasket, install new gasket, button up motor.
Repeat as necessary!
Mon Aug 17, 2009 10:30 pm
I wish,my chit is leaking again
Tue Aug 18, 2009 4:05 am
Tooltime...
http://www.youtube.com/watch?v=AV2MehkF ... re=related
Tue Aug 18, 2009 6:49 am
Tue Aug 18, 2009 6:50 am
I had about 20hrs on mine and it was leakign when i got it. I tightened the bolts down myself and never had a problem........
Its probably because i used a left handed metric torque wrench. :shock:
Later
Tue Aug 18, 2009 7:32 am
Tue Aug 18, 2009 7:47 am
Weld it up
Tue Aug 18, 2009 7:56 am
TOOL HOLDER :o
Tue Aug 18, 2009 7:58 am
use 3/8 studs instead of the 8mm bolts. Got 32 hours on stage 3 and no leaks yet.
There is no replacement for displacement!!!!
Tue Aug 18, 2009 8:08 am
Tue Aug 18, 2009 8:36 am
Run it
Tue Aug 18, 2009 9:02 am
Man I don't want to type this ...... mines leaked just a bit .. not much ... Hoyt at Gator-Tail did some mods 'bout 165 hrs ago and no leaky no mo !!!
Dang I hopes I didn't put the kiss on it !! :|
Tue Aug 18, 2009 2:27 pm
Tue Aug 18, 2009 3:44 pm
Tue Aug 18, 2009 3:46 pm
i have 71hrs on a stock briggs Gasket but I used some High perf copper silicone on both sides of the gasket.
Tue Aug 18, 2009 4:14 pm
24x60 Dual Prodrives
Tue Aug 18, 2009 4:47 pm
I had nearly 200 hrs. on EVT's case gasket with studs in my block..... until I punched a gaping hole in da side of my block. lol
Tue Aug 18, 2009 6:06 pm
What caused the gap in said block SG? Did you through a rod?
Tue Aug 18, 2009 6:08 pm
prolly so, ain't even tore it apart. just yanked it off, threw it on da floor in my shop, and put my 60 in it's place. Been runnin dat ever since. I'm too fed up with hopped up bullshit right now to fork with it.
Tue Aug 18, 2009 6:24 pm
Stumpy just out of curiosity, what mods does your motor have?
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Aug 18, 2009 6:49 pm
stage 1 + cam..... my rev. limiter had crapped out.... and so had my givashitter.
Tue Aug 18, 2009 6:52 pm
Locktite and a torque wrench. Studs are only as good as the material your putting them in. Also if / when you open it up you'll see in the upper left and lower right an area that will accept a bolt through bushing that has been already machined into the block.
Tue Aug 18, 2009 7:10 pm
Tue Aug 18, 2009 8:38 pm
Wrong puter right now, but I'll post pics this weekend. ;)
Tue Aug 18, 2009 8:50 pm
mines leaking as we speak
Tue Aug 18, 2009 9:34 pm
Tue Aug 18, 2009 9:36 pm
Wed Aug 19, 2009 6:19 am
Wed Aug 19, 2009 8:09 am
"Just because I don't respond doesn't make me dumb, just waiting for the retards to quit babbling."
Wed Aug 19, 2009 8:16 am
lost de givashits a few weeks back...
nows i got a bad case of de phuckits :lol:
Wed Aug 19, 2009 8:19 am
Like MitchV said in the block there is a place for some hollow dowl pins that should of been installed at the factory about .393 size but was not if you ever worked on a old three wheeller you know what I am talking about, Briggs made a bad design when they used the little .250 dowl pins that is close together and the case cover is .375 this gives the case cover area slop which starts to twist wareing out the gasket then causeing the bolts to be lose cause the gasket actually gets thinner to the metal insert then that when it blows. Because when you go to stage 1-3 the tourque is amplified it makes it worse. If you bore the case cover to .375 which it already basically is, except for casting metal left over and tap the 8mm block hole to .375 you have a machined fit that can't twist cause the studs then also act as 11 .375 dowl pins directly accross from each other, this stops the twisting action then stops gasket failure. I did this and haven't had any problems yet though I only got about 32 hours since I fixed it. If it fails I'll let yall know. If I would of had time I would of machined two .393 dowl pins to fit the case/cover and it probably would of fixed it also.
Thu Aug 20, 2009 8:38 am
Thu Aug 20, 2009 9:05 am
Can't find the photos, but basinlover pretty much summed it up.
I'm surprised none of the MM technicians haven't caught this yet.
Thu Aug 20, 2009 11:15 am
Thu Aug 20, 2009 12:54 pm
Thu Aug 20, 2009 4:52 pm
Thu Aug 20, 2009 8:50 pm
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Mon Aug 24, 2009 3:25 pm
Josh
Max Lucado
Mon Aug 24, 2009 3:28 pm
