It is currently Wed Apr 24, 2024 7:37 pm
getsometailgtr35
Joined: Wed Dec 05, 2012 1:09 pm Posts: 32 Location: Metairie La.
Re: GTR 35 REBUILD (PICS)
Please do yourself a favor install some anodes on your motor. the shaft support, on the bottom of the mounting bracket. add a ground wire from motor mounting bracket. wish I had done this on my first motor. new still looks good. cheap spray works fine. marvel mystery oil for rust and to prevent.
_________________ If You Don't Think Bad Things Happen !!!!!!!!!!!!!!
Fri Jun 07, 2013 9:29 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
nice looking project, hey bud after you pulled the planetary when you pulled the gear and cluth, what method you use. ive been prying at it a little bit. Heard its suppose to be a 3 piece design. any info would be appreciated, once i see the cluth will probaly be easier to figure out.
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Wed Jun 12, 2013 3:55 pm |
MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
I welded up 2 peices in the shape of a U with an I that connects across the top of the U and another piece that goes - way. One for behind the clutch and one for in front. With 2 long peices of allthrEAD CONNECTING THE 2 u PEICES. All you ahave to do it tighten up against your crank shaft and then tighten down equally on each side and it breaks everything loose. Its hard to describe bur basically its a puller to get the clutch and everything to slide off. If you mover the clutch .5" mose of the time thats enough to get your gear to break looke in my experiances. It works pretty slick. Too bad I'll never have to use it again cause never seize is my new friend! I spent a couple hours making it but it works damn good. No I dont have pictures of it either. I am on the road right now doing pipeline work trying to pay for all of my Mud Motor bills....
Wed Jun 12, 2013 4:20 pm |
DmaxHunter
thats fine dont need a pic, i am going to get a a buddy and a three jaw gear puller, should break loose.
Thu Jun 13, 2013 8:19 am |
MALLARDSX2
Reviving this thread.
I have started assembly.
Only took me 5 years. lol
Were the hell does the time go?
Tue Jul 03, 2018 8:23 am |
Users browsing this forum: No registered users and 469 guests |
