It is currently Tue Sep 16, 2025 9:43 pm
Reply to topic  [ 7 posts ]
 Checking the stator
Post Checking the stator
I have a Kohler 27. I don't know for sure, but I suspect that my motor is not charging the battery like it should... can you check the stator just like an alternator, or is there a different method?
24x60 Dual Prodrives
Mon Jan 26, 2009 2:14 pm
Post Re: Checking the stator
I don't think you can stick a wrench to the back of it and see if it sticks :lol:
I think it is up under the flywheel but I could be wrong. Seems like there is a rectifier or something like that in the system too.
Best bet would probably be to call the local lawn mower repair shop and ask them how to test, may be as simple as hooking a voltage meter up
Kook you got it all wrong, that is the method for checking the plug wires :shock:
OneBigAssMistakeAmerica
Mon Jan 26, 2009 11:08 pm
Put a meter on the battery and rev up the rpms. Should show about 14.5v if working properly. Battery should be 12-12.5v and you will NOT see a change after reving the motor if its not charging. I believe those are the numbers anyway.
18x48 Charles Leonard / 36PD
Tue Jan 27, 2009 12:16 am
It all starts on page 130 or so.
http://www.kohlerengines.com/common/res ... 2450_c.pdf
But like Poker said, that is the easiest way to begin.
Tue Jan 27, 2009 7:21 am
The rectifiers are notorious for going out on these motors. Test the output with a mutlimeter and if the voltage is low at 2k RPMs, that most likely is the cuprit.
Fri Jan 30, 2009 3:46 pm
Pull the rotor and gurter....cross tap wires to check for spark-
Spark good....no spark bad.
Sun Feb 01, 2009 6:59 am
May be a stupid ques. but how old is your battery? That too may be the culprit.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Sun Feb 01, 2009 7:43 am
