Anybody seen this oil leak spot? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=40 |
Author: | willett [ Wed Jan 14, 2009 5:14 pm ] |
Post subject: | Anybody seen this oil leak spot? |
Noticed this couple weeks ago when changing my clutch Anyone else ever seen oil sheen/leak in this spot on 36 Vert? |
Author: | River [ Wed Jan 14, 2009 5:31 pm ] |
Post subject: | Re: Anybody seen this oil leak spot? |
Case gasket |
Author: | BROOKS [ Wed Jan 14, 2009 6:49 pm ] |
Good eye Rivers !!!! I thank the bolt on the left needs just a little tightn' up and you be good to go. |
Author: | Brinkleydog [ Thu Jan 15, 2009 10:25 am ] |
every time i go out i see that.........good luck. I'm going to tie mine to each other then i get time to drill pilot holes for the wire. How many minutes can u run before you have to tighten you bolds? it get about 12-40 min...................I HATE CASE GASKETS.............. |
Author: | Silkpower [ Thu Jan 15, 2009 11:41 am ] |
When you tear it down to replace the gasket you need to stud the base bolts & use lock nuts thay hold better the studs you will need are 8mm x 1.25 x 70mm seems to work well in the testing we have done ![]() |
Author: | bayouboy [ Sat Jan 17, 2009 10:04 pm ] |
That sounds like it might be a winner Silk! |
Author: | Brinkleydog [ Mon Jan 19, 2009 9:59 am ] |
If you want to just take the bolts out one at a time and put new lock-tight on them. did this on all the bolt i could get to (without taking anythign off) and it held for 5 hours this weekend. Im going to take the pipe off today and get that one. DO NOT DO THIS MORE THAN A FEW TIME YOU WILL STRIP OUT THE THREADS...then you will have to stud it like Silk said. Silk what you charge to stud a 36 pd out? Later |
Author: | willett [ Mon Jan 19, 2009 10:23 am ] |
not too worried bout it right now got barely a week left in season then will be goin back to them to get some more put into the motor and have gasket changed |
Author: | Pappy Gander [ Mon Jan 19, 2009 6:13 pm ] |
I've run a case gasket leak all season and just watched the level. Run about 20 hrs and it hasn't gone down much. I'll fix it when I get around to it in the off season. ![]() |
Author: | Mudgun [ Fri Jan 23, 2009 7:24 am ] |
Just run thicker oil. ![]() |
