It is currently Fri Jun 19, 2026 10:15 pm
Reply to topic  [ 10 posts ]
 2010 35hp cdi not charging
Post 2010 35hp cdi not charging
my 2010 gtr is not charging a battery what should I look into first
16x44 Hanko Skiff
35GTR
Wed Feb 20, 2013 11:28 am
Post Re: 2010 35hp cdi not charging
Wed Feb 20, 2013 11:29 am
your voltage regulator on the side of your motor, check it with a voltage meter to see what voltage it is putting out.
Wed Feb 20, 2013 11:31 am
Check ur battery 1st
Wed Feb 20, 2013 3:11 pm
Check the red wire from the VR with a voltmeter- should be putting out 12V at idle and up to 14.4 at ~3500 RPM.
Wed Feb 20, 2013 9:10 pm
red wire is not reading anything on a voltage meter
16x44 Hanko Skiff
35GTR
Sun Feb 24, 2013 12:10 pm
Check the yellow wires from the stator for AC volts on the other side of the voltage regulator, if there is voltage there, its the regulator needing to be replaced.
Sun Feb 24, 2013 4:47 pm
put a voltage meter on it today and it's not reading anything from the red wire or the plug that comes from the fly wheel
16x44 Hanko Skiff
35GTR
Wed Jun 05, 2013 7:44 pm
Have u ever crossed the pos and neg wires on your battery? This will toast your regulator if u have....
Prodigy Boats
https://www.facebook.com/Prodigyboats
www.prodigyboats.com
Contact for info - http://prodigyboats.com/contact-us/
706-253-7766
Wed Jun 05, 2013 8:47 pm
no I have not
16x44 Hanko Skiff
35GTR
Thu Jun 06, 2013 5:27 am
