It is currently Tue Jun 24, 2025 11:07 am
Reply to topic  [ 7 posts ]
 36 PD?
Post 36 PD?
When i am running my motor in the water i am getting some bubbles in the fuel filter as if it has air in the line. It doesnt do it at all when I am not running it in the water though. I am getting 4100 out and only getting 3750 for peak speed in the water. I just upgraded to the Iron Mountain heads and dual x over exhaust. Are these bubbles a problem? should I be getting some better proformance?
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Mon Aug 31, 2009 9:05 am
Post Re: bubbles in filter
Yes, you have an air leak somewhere in the fuel line. Check all of your connections well. Where is your gas tank located and what do you have connected to the fuel line (primer bulb, fuel filters, quick connects, etc)?
Mon Aug 31, 2009 9:51 am
Your pulling air in upstream of da filter sumwhere. Find it.
Mon Aug 31, 2009 9:53 am
i am pretty sure I know where it is. I will fix that. Now for the second part, Should I be getting better proformance? I adjusted the valves to .005 but havent done anything to the carb. should I adjust it? I would also like to adjust the govorner but cant make heads or tails of that cluster$&(#
Mon Aug 31, 2009 10:30 am
what size motor are you running?
Mon Aug 31, 2009 10:58 am
36 PD on an Excel Mid West 1754
Mon Aug 31, 2009 12:31 pm
Your RPM's sound about right, but I don't run a PD so wait for sumone who know a little more than me to chime in.
Mon Aug 31, 2009 12:54 pm
Users browsing this forum: Majestic-12 [Bot] and 100 guests
