It is currently Sun Apr 12, 2026 4:27 pm
Reply to topic  [ 4 posts ]
 RPM"S not coming up
Post RPM"S not coming up
need a little help. Have a new gator tail that reves up to about 3500 rpms and then starts hunting real bad. Does not do this in the water but only gets to about 3300 to 3500 rpms. Put a pint of seafoam in the fuel and running it now. Any suggestions?
Thanks in advance!
Thu Sep 10, 2009 5:14 pm
Post Re: RPM"S not coming up
Sounds like the gov. is set low. You can adjust the RPM up by adjusting it.
Thanks
Fri Sep 11, 2009 5:48 am
at least they arent going down. ;)
Geckers right, check out your governer.
BUCK OFAMA
Sat Sep 12, 2009 8:20 pm
I tried the gov trick ,had Warren Coco walk me thru that and thats what got me up to about these numbers.....i was thinkin about checkin compression next but i didnt know if this might be a sign of low compression or not........Oh and i definitely agree, at least it aint goin down no more
Sun Sep 13, 2009 2:56 am
