It is currently Sun Apr 12, 2026 8:26 pm
Reply to topic  [ 8 posts ]
 Engine problem
Post Engine problem
My GTR 35 will start and run fine at higher rpms but will not idle. I changed my filter and put new gas but still no luck. Anyone have some advice? Thanks
Sun Sep 13, 2009 8:08 pm
Post Re: Engine problem
Put yer face in the myrtles.
Sun Sep 13, 2009 9:21 pm
It will run really rough at low rpms and then kill, I checked the choke and it is working, also it will idle if the choke is pulled.
Sun Sep 13, 2009 9:52 pm
How old is the engine?
BUCK OFAMA
Sun Sep 13, 2009 9:53 pm
One year old, has 38 hours on it.
Mon Sep 14, 2009 5:33 pm
Sounds like you got some bug junk in it somewhere, or maybe it's running too lean. Give er a good cleaning and blow it out real good, maybe that'll help.
Mon Sep 14, 2009 9:34 pm
Whats your idle set at? Might be too low, but the odd thing is that it will idle with the choke pulled somewhat?
Tue Sep 15, 2009 8:34 am
Thats means your a lil lean. Check your carb. Maybe It needs a cleaning.
Did you mess with you A/F screws at all?
BUCK OFAMA
Tue Sep 15, 2009 1:31 pm
