Engine problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=4577 |
Author: | Theriot81 [ Sun Sep 13, 2009 8:08 pm ] |
Post subject: | Engine problem |
My GTR 35 will start and run fine at higher rpms but will not idle. I changed my filter and put new gas but still no luck. Anyone have some advice? Thanks |
Author: | DeathMetalDukk [ Sun Sep 13, 2009 9:21 pm ] |
Post subject: | Re: Engine problem |
Author: | Theriot81 [ Sun Sep 13, 2009 9:52 pm ] |
It will run really rough at low rpms and then kill, I checked the choke and it is working, also it will idle if the choke is pulled. |
Author: | bjg [ Sun Sep 13, 2009 9:53 pm ] |
How old is the engine? |
Author: | Theriot81 [ Mon Sep 14, 2009 5:33 pm ] |
One year old, has 38 hours on it. |
Author: | DeathMetalDukk [ Mon Sep 14, 2009 9:34 pm ] |
Sounds like you got some bug junk in it somewhere, or maybe it's running too lean. Give er a good cleaning and blow it out real good, maybe that'll help. |
Author: | MaXXis85 [ Tue Sep 15, 2009 8:34 am ] |
Whats your idle set at? Might be too low, but the odd thing is that it will idle with the choke pulled somewhat? |
Author: | bjg [ Tue Sep 15, 2009 1:31 pm ] |
Thats means your a lil lean. Check your carb. Maybe It needs a cleaning. Did you mess with you A/F screws at all? |
