It is currently Fri Sep 19, 2025 1:22 pm
[ 8 posts ] |
Theriot81
 Engine problem
My GTR 35 will start and run fine at higher rpms but will not idle. I changed my filter and put new gas but still no luck. Anyone have some advice? Thanks
Sun Sep 13, 2009 8:08 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: Engine problem
_________________ Put yer face in the myrtles.
Sun Sep 13, 2009 9:21 pm |
Theriot81
 Re: Engine problem
It will run really rough at low rpms and then kill, I checked the choke and it is working, also it will idle if the choke is pulled.
Sun Sep 13, 2009 9:52 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: Engine problem
How old is the engine?
_________________ BUCK OFAMA
Sun Sep 13, 2009 9:53 pm |
Theriot81
 Re: Engine problem
One year old, has 38 hours on it.
Mon Sep 14, 2009 5:33 pm |
DeathMetalDukk
 Re: Engine problem
Sounds like you got some bug junk in it somewhere, or maybe it's running too lean. Give er a good cleaning and blow it out real good, maybe that'll help.
Mon Sep 14, 2009 9:34 pm |
MaXXis85
 Re: Engine problem
Whats your idle set at? Might be too low, but the odd thing is that it will idle with the choke pulled somewhat?
Tue Sep 15, 2009 8:34 am |
bjg
 Re: Engine problem
Thats means your a lil lean. Check your carb. Maybe It needs a cleaning.
Did you mess with you A/F screws at all?
Tue Sep 15, 2009 1:31 pm |
[ 8 posts ] |
