PD trim switch
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=46011
Author:  NoHomeaux [ Thu Oct 03, 2013 5:14 am ]
Post subject:  PD trim switch
I'm having problems with my friggin trim switches. I've only been having the boat for a year and im on my 3rd one. Warrenty is about to go out and was wondering if anybody has tried any other type of switch. Thanks yall.
Author:  Will [ Thu Oct 03, 2013 5:24 am ]
Post subject:  Re: PD trim switch
Take all that crap off and put on a winch solenoid. You can convert everything for less money than one PD trim switch.
Author:  Will [ Thu Oct 03, 2013 5:26 am ]
Author:  Will [ Thu Oct 03, 2013 5:29 am ]
Here's a solenoid.
http://www.amazon.com/gp/product/B004VA ... UTF8&psc=1
And the switch, but there are many options on switches. this one is ready to go and has the spades that fit said solenoid.
http://www.amazon.com/ATV-Rocker-Switch ... auto_img_y
Run power straight from the battery to the solenoid and you can get the power for the switch off the starter.
Author:  missile [ Thu Oct 03, 2013 6:07 am ]
http://www.colehersee.com/home/item/cat/198/24452/
I was told to order this one so I ordered two one for each motor. I am tired of relays popping.
Author:  missile [ Thu Oct 03, 2013 6:12 am ]
Also would like to know how many amps the new parker trims draw cause I need to figure out if I can stay with the 12 gauge wire I have or will I need to up it to 10 gauge for a 7-8' run since I am moving the new relays to inside the boat.
Author:  Will [ Thu Oct 03, 2013 6:31 am ]
I ran 10awg and my longest wire is only 3', not sure about the new parker trim but I checked mine. For the most part it would be around 65 amps on average but after using it repeatedly and putting a bind on it I saw it jump as high as 144 amps. The solenoid I'm using now will take up to 175 amps for 5 seconds. The trim and reverse works much better, faster and smoother and I've had zero issues with it. The old style switches were a constant PITA and with the heavy resistance when they started acting up would make everything slow.
Author:  NoHomeaux [ Thu Oct 03, 2013 6:48 am ]
Thanks Will, ill definately give it a try!
Author:  missile [ Thu Oct 03, 2013 8:42 am ]
Author:  Will [ Thu Oct 03, 2013 8:47 am ]
Yep, it doesn't happen all of the time but only takes once to fry a relay. :lol:
Author:  banded-mallard [ Thu Oct 03, 2013 8:49 am ]
Author:  missile [ Thu Oct 03, 2013 9:28 am ]
Will do you see anything wrong with the one I posted besides cost think they were like 50.00 each.
Author:  Will [ Thu Oct 03, 2013 10:13 am ]
Author:  Will [ Thu Oct 03, 2013 10:19 am ]
Actually I just found a cheaper price on the Trombetta reversing solenoid, looks like they're around $60 each for that brand...
http://www.amazon.com/Trombetta-Reversi ... B007W2NBTQ
http://www.trombetta.com/cm/pdfs/D03508RevD.pdf
Author:  banded-mallard [ Thu Oct 03, 2013 11:10 am ]
Didn't I read somewhere (can't find on here) that someone wired this up without any problems on a 3-wire setup.
Author:  missile [ Thu Oct 03, 2013 11:27 am ]
Author:  tman52804 [ Fri Oct 04, 2013 12:47 pm ]
Anyone have pictures of where they mounted the solenoid?
Author:  Will [ Sat Oct 05, 2013 6:57 am ]
Put mine in the transom. Then you can put the wires in the flex conduit or box it in or put caps on the studs...
Author:  autogateman [ Sat Oct 05, 2013 10:34 am ]
Author:  wacknstack [ Tue Nov 19, 2013 2:02 pm ]
Author:  btmannin [ Tue Nov 19, 2013 2:55 pm ]
Author:  okredleggs [ Wed Aug 05, 2015 7:05 pm ]
Appreciate the photos and ideas on the PD trim switch, and I think will be doing the same re-wire on mine. How do you protect the relay from water once its installed on the transom?
Thanks,
Author:  banded-mallard [ Thu Aug 06, 2015 4:54 am ]
You don't, there sealed. I used dielectric grease on the terminals to protect them, but as far as the internals, your good.
Author:  okredleggs [ Thu Aug 06, 2015 2:57 pm ]
Good deal, thank you.
Author:  okredleggs [ Sat Aug 20, 2016 4:58 pm ]
Finally getting around to this...you mention the switch has power from the starter. Is this the ignition starter to the switch?
Thanx
