It is currently Wed Jun 25, 2025 11:01 pm
[ 8 posts ] |
Gator Tail blowing fuses while frogging
SmokeEater829
Joined: Sat Jun 13, 2009 8:48 pm Posts: 1830 Location: Belle Chasse, LA
Last night we went to do a little frogging in my buddy's boat. Two times while we were out frogging, his motor blew the 25 amp fuse. The motor died and wouldn't restart. Changed the fuse, motor cranked right up. Is this a common problem when flipping the switch in and out of neutral? We were going into and out og gear ALOT. My buddies boat is idled really high, so we would bump it into and out of gear to keep the speed down.
Anyway, is this normal or is something wrong? If it isn't right, what should he be checking??
Thanks!
_________________ Mud Buddy 4500 Black Death hauling the Uncle J 18x58
Tue Sep 22, 2009 9:05 pm |
WestEndAngler
MMT Moderator
 Re: Gator Tail blowing fuses while frogging
Sounds like a wire is frayed under the cover... check the wires under the trim and start / forward cover... perhaps is shorting out somewhere.
Tue Sep 22, 2009 9:07 pm |
godvl
Joined: Fri Feb 06, 2009 8:36 am Posts: 253 Location: Nac-o-no where, tx
x2 you got a wire touchin metal or somethin, check the wire that plugs into the clutch, if its only blowin the fuse when you engage and disengage, that what it would be.
Tue Sep 22, 2009 9:21 pm |
WestEndAngler
MMT Moderator
Tue Sep 22, 2009 9:32 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
No thats not normal.
Thats got nothing to do with engaging and disengaging the clutch,it is a short somewhere.It may have seemed like it was the clutch if it was happening when engaging/disengaging it idling high and jerking the motor and moving the wire causing it to ground.Look for a worn spot or a bad connection.
Now while frogging if you loose the ability to trim up but you can still trim down or vice versa its a short on the trim wires under the cover.I've had this happen while frogging. Now to the things that matter,how were the frogs?
Wed Sep 23, 2009 3:49 am |
SmokeEater829
Frogs weren't really out. Ended up with 25. Were only out for about an hour or so. But it was still a blast.
Wed Sep 23, 2009 6:13 pm |
JBREAUX
Joined: Tue Jan 13, 2009 8:12 pm Posts: 412 Location: soufff la
Wed Sep 23, 2009 6:24 pm |
dog walker
Thu Sep 24, 2009 3:29 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 116 guests |
