It is currently Wed Jun 25, 2025 11:00 pm
[ 4 posts ] |
WI WATERFOWL
 adjusting idle ?
anyone know how to lower the idle on a 24 hp honda off hand. I belive im a little high i run 2400 rpm out of water idle. thanks
Sun Oct 04, 2009 12:22 pm |
bundy
Joined: Sun Apr 05, 2009 8:35 pm Posts: 1232 Location: souf louisiana
 Re: adjusting idle ?
they should have a governer screw on ur carb back it out a lil until it turns down that should work
_________________ BUNDY BUILT SKIFFLESS cuz der bad ass like dat....
bunnny rabbit customs.
Sun Oct 04, 2009 12:24 pm |
WI WATERFOWL
also what rpm should i be tring to get it down too?
Sun Oct 04, 2009 9:39 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
If you take off the breather, and you are standing in front of the motor, it's a screw on the left side of the carb, with part of the linkage resting on the bottom end of it. When you turn it it pushes against the linkage to raise/lower the rpm's, you'll hear it. Mine runs about 1200 out of the water, i'd say just lower it until it idles smoothly but won't bog down bad when you drop the prop in the water. I need to get a tach for mine.
_________________ Put yer face in the myrtles.
Sun Oct 04, 2009 9:55 pm |
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 116 guests |
