It is currently Sat Nov 22, 2025 4:05 am
Reply to topic  [ 19 posts ]
 Opinions on spark plugs...
Post Opinions on spark plugs...
I have a 36 pd with a mikuni carb bps filter and what's looks to be gecker duals...what plugs are y'all running in similar rigs?
Wed Mar 12, 2014 4:42 am
Post Re: Opinions on spark plugs...
Refurbishing a Prodrive
Wed Mar 12, 2014 6:31 am
For what it is worth, I havent found a single plug out there that will last as long as what Briggs recomends (Champion RC12YC) to put in the motor.
In regards to your specific motor, being that you dont have anything advancing the spark or have increased the compression with heads decked an excessive amount or longer connecting rods (so that you have to run a higher grade of gas), I dont see any benefit at all in using anything but what Briggs recomends to put in the motor.
Wed Mar 12, 2014 10:00 am
what about the Briggs & Stratton 5066K Platinum Spark Plug are these a good replacement?
Wed Mar 12, 2014 10:09 am
What do you use on your lawn mower? ;)
Wed Mar 12, 2014 10:17 am
with FX600V Kawasaki I use NGKs
Wed Mar 12, 2014 10:21 am
Wed Mar 12, 2014 11:32 am
Wed Mar 12, 2014 12:14 pm
Champions (period) !
Wed Mar 12, 2014 12:53 pm
GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Wed Apr 09, 2014 8:08 am
"Champion RC12YC" get them just about anywhere for $2 each.
Wed Apr 09, 2014 8:10 am
So the same as the Boat Dr said above.. NO matter if your motor is stock or mods?!
thanks!
Wed Apr 09, 2014 8:14 am
Hook a blower to that sob and you can still use the Champions :lol: Plus, in my opinion they give you the best mixture reading.
Wed Apr 09, 2014 8:18 am
good deal
Wed Apr 09, 2014 8:48 am
I've always ran the NGK replacement plugs and never had an issue.
1754 Gatortail Extreme / 35 GTR
Wed Apr 09, 2014 11:14 am
NGK's work fine also but why when you can run a $2 Champion, also the NGK's tend to over exaggerate the mixture to be lean.
Wed Apr 09, 2014 11:19 am
Wed Apr 09, 2014 11:25 am
Well hell, run either then :lol:
Wed Apr 09, 2014 11:29 am
I've had good luck with the autolite app3923's
Wed Apr 09, 2014 11:45 am
