| Marine grade motor?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=5216 |
| Author: | yak [ Fri Oct 09, 2009 7:52 pm ] |
| Post subject: | Marine grade motor?? |
Ordered a new prodrive this week. Peck said the new motors are coming with a stainless exhaust now. Anyone seen these exhast?? |
| Author: | dog walker [ Fri Oct 09, 2009 8:33 pm ] |
| Post subject: | Re: Marine grade motor?? |
They look just like the regular stock exhaust except they are stainless,at least thats what the one I have seen looks like. |
| Author: | OwenDickeson [ Fri Oct 09, 2009 8:39 pm ] |
the motors also come with a 50 amp charging system instead of 20. they have a different ignition with a lighter flywheel???that is supposed to idle better and have better throttle response. and also a different fuel pump set up so there are no problems with vapor lock or a need for an external fuel pump. i will be pickin up my rig next weekend or the week after and i will post up some pics and a review when i get it. |
| Author: | BODUKE_7 [ Fri Oct 09, 2009 8:58 pm ] |
THAT IS AWEET I THINK THEY ALL SHOULD COME WITH A STOCK STAILESS EXHAUST OR AL LEAST HAVE THE OPTION |
| Author: | muddiejeep [ Sat Oct 10, 2009 7:41 am ] |
kyle at GT said that briggs has been working on building a SS exhaust for a few months. Glad they are willing to try to do something that will help the MM guys, even thought we are a small percentage of their customers. |
| Author: | WestEndAngler [ Sat Oct 10, 2009 7:43 am ] |
50AMPS? Sweet! Now I can install a full radio system system that will bounce my rig all the way down the bayou |
| Author: | dog walker [ Sat Oct 10, 2009 8:10 am ] |
Here is a pic of a stainless briggs exhaust with about 30 hours on it |
| Author: | yak [ Sat Oct 10, 2009 2:43 pm ] |
Thanks for the picture. So its the same exhaust style, just in stainless. I think he also said it has a built in rev limiter also. |
| Author: | dog walker [ Sat Oct 10, 2009 9:07 pm ] |
| Author: | muddiejeep [ Sat Oct 10, 2009 9:21 pm ] |
Whats this built in rev limiter about. I know there is a govenor system built in the older motors. |
| Author: | dog walker [ Sat Oct 10, 2009 9:32 pm ] |
| Author: | muddiejeep [ Sat Oct 10, 2009 9:41 pm ] |
Is it electical or what? The gov. kicks in at 4250, so what is the point of changing it? |
| Author: | Triple Threat [ Sun Oct 11, 2009 8:47 pm ] |
i have the ss mufflers with 147 hrs looks great and is holding up well. these are/were proto types send straight from briggs at the time... so i do not know if they are any different than the ones in production |
| Author: | LA OUTLAW [ Sun Oct 11, 2009 8:56 pm ] |
Hey dog walker is it possible for a briggs service center to replace the charging system on older motors with the 50 amp charging system? |
| Author: | dog walker [ Sun Oct 11, 2009 9:08 pm ] |
That I do not know,if it would just be the stator and rectifier it would not be bad but I don't know what else you would have to change to switch over |
| Author: | LA OUTLAW [ Sun Oct 11, 2009 9:10 pm ] |
I need that new system bad!!!! I'm sure everyone else feels the same way....20 amps sucks if I idle to long it wears my battery out!!! Froggin is hell on a battery!!! |
| Author: | BROOKS [ Mon Oct 12, 2009 4:53 am ] |
Ifin' the new Briggs is comin' with stanless mufflers ..... it looks like thay would have a part number fo the replacement. |
| Author: | River [ Mon Oct 12, 2009 6:27 am ] |
| Author: | dog walker [ Mon Oct 12, 2009 7:28 am ] |
| Author: | brlcla [ Mon Oct 12, 2009 4:09 pm ] |
This new chargins system came out in 2003... http://www4.briggsandstratton.com/displ ... ocid=22748 http://www4.briggsandstratton.com/displ ... ocID=76236 Page that shows details and part numbers... #841178 http://www4.briggsandstratton.com/miscp ... tor_id.pdf It does not show the 61 Series (35 HP) motor but it shows the 54 Series (31 HP). Need a Briggs guy to explain why its not listed for the 35 HP as an option. |
| Author: | OwenDickeson [ Mon Oct 12, 2009 6:49 pm ] |
| Author: | POKER1 [ Mon Oct 12, 2009 7:19 pm ] |
| Author: | LA OUTLAW [ Mon Oct 12, 2009 7:20 pm ] |
Them bastards know that is a must on MM why the hell isn't it a standard Item on all of them!!!! I'm callin prodrive tomorrow!!!! |
| Author: | schrieverboy [ Mon Oct 12, 2009 7:28 pm ] |
| Author: | OwenDickeson [ Mon Oct 12, 2009 7:39 pm ] |
details of the new motor better explained - Digital CDI Ignition that allows motors to run at a low idle or trolling speed. This is ideal for docking, decoy retrieval and trailering. - Lighter Flywheel means a more responsive engine. - Stainless Steel Muffler resists corrosion in saltwater and brackish water. - High-Capacity Fuel Pump runs cooler and delivers better performance. - 20/50 Amp Alternator to run electronic clutches, a fish finder, GPS, running lights, finder lights, or a radio. |
| Author: | POKER1 [ Mon Oct 12, 2009 8:04 pm ] |
| Author: | LA OUTLAW [ Mon Oct 12, 2009 8:07 pm ] |
I just ordered 4 of em' for this season you can frog with em, shoot ducks with em hell you can even fuk with em on!!!! |
| Author: | POKER1 [ Mon Oct 12, 2009 8:09 pm ] |
| Author: | LA OUTLAW [ Mon Oct 12, 2009 8:11 pm ] |
| Author: | schrieverboy [ Mon Oct 12, 2009 8:21 pm ] |
| Author: | LA OUTLAW [ Mon Oct 12, 2009 8:45 pm ] |
