| 16hp vanguard fuel problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=5242 |
| Author: | turnquij [ Sun Oct 11, 2009 4:17 pm ] |
| Post subject: | 16hp vanguard fuel problem |
I recently picked up this used vanguard, did the routine stuff, plugs, oil & filter change, cleaned up the flywheel, cleaned the carb (no mods), new fuel filter, new fuel hose and vacuum hose, new tank with a primer bulb & fuel pump. Once the motor is warmed up it will idle fine as soon as I run at higher RPM or put a load on it it will only run for about 1 min before running out of fuel and starts to die, if I close the choke it will come back to life. In addition at mid throttle if I squeeze the primer blub periodically it will run ok. I hope someone can help with this, VERY FRUSTRAITED Thanks JIm |
| Author: | turnquij [ Mon Oct 12, 2009 11:07 am ] |
| Post subject: | Re: 16hp vanguard fuel problem |
would a restricted vacuum hose cause this problem? I noticed the new hose I installed had a kink in it, so I shortened hose. Motor seems to run better and it will start without the choke now. I did the pray thing hoping that this has fixed the problem, will not truely know until i put in the water. I guess I was ment to figure this one out myself |
