KABOOM PICS http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=5283 |
Page 1 of 2 |
Author: | deltaduckmaster [ Mon Oct 12, 2009 6:50 pm ] |
Post subject: | KABOOM PICS |
Think this will stop you dry in your tracks!!! |
Author: | OwenDickeson [ Mon Oct 12, 2009 6:51 pm ] |
Post subject: | Re: KABOOM PICS |
i dont see whats wrong with it? ![]() ![]() ![]() ![]() |
Author: | schrieverboy [ Mon Oct 12, 2009 7:10 pm ] |
ddm sorry for your current loss.. prayers sent ![]() so what now?? |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:10 pm ] |
From the looks of it Terry, you dropped a valve!!!! |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:11 pm ] |
Are those oem pistons? |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:14 pm ] |
Author: | bjg [ Mon Oct 12, 2009 7:15 pm ] |
After some failure analysis Hoyt and I think we know what did the damage. Whos wants to guess? It was not a drop valve. |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:16 pm ] |
More like a donut top. |
Author: | deltaduckmaster [ Mon Oct 12, 2009 7:17 pm ] |
Author: | JBREAUX [ Mon Oct 12, 2009 7:18 pm ] |
Author: | schrieverboy [ Mon Oct 12, 2009 7:19 pm ] |
wrist pin failure?? |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:21 pm ] |
Cam broke. |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:21 pm ] |
Well if it wasn't a dropped valve it was that broken a$$ cam BJ |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:24 pm ] |
From the pics, looks like your block made it. Did it? |
Author: | craig [ Mon Oct 12, 2009 7:25 pm ] |
Looks like the engine was running lean on that cylinder if you ask me. A lean running cylinder will cause early detonation which in turn will cause that cylinder to overheat which will then go kaboom. ![]() Don't ask me how I know this. |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:25 pm ] |
Nope the block has a crack in it!!!! |
Author: | JBREAUX [ Mon Oct 12, 2009 7:26 pm ] |
Author: | deltaduckmaster [ Mon Oct 12, 2009 7:27 pm ] |
Author: | quackconsumer [ Mon Oct 12, 2009 7:27 pm ] |
Seein a new MM engine in pieces on a floor jack will make you sick to your stomache. |
Author: | deltaduckmaster [ Mon Oct 12, 2009 7:28 pm ] |
Author: | bjg [ Mon Oct 12, 2009 7:30 pm ] |
The rod broke the cam. Cam was broke in two spots not one. Looks like it was the hole in the carb boot sucking in un metered air. Both the cylinders had hot spots and both spark plugs were white. The number two cylinder always runs leaner that the other "which is the on that failed". It looks like the number two side got way to hot, siezed the piston, pulled the wrist pin out the piston and went to work. Thats why it locked up as fast as it did. As Hoyt stated " A 20lb flrwheel has alot of force when its turning 4 grand". |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:31 pm ] |
Oh and Terry Correction I'm a DIESEL MECHANIC Not a LAWNMOWER Specialiest!!!!! |
Author: | bayouboy [ Mon Oct 12, 2009 7:31 pm ] |
wrist pins in one piece as well as the top pin hole on the connecting rod looking at whats left of the piston and seeing that the connecting rod pushed though it. looks like piston failure? |
Author: | schrieverboy [ Mon Oct 12, 2009 7:33 pm ] |
ive seen rods bend and cause it to lock up but never jus turn to ground meat like dat.... number 2 coolest thing ive seen today |
Author: | quackconsumer [ Mon Oct 12, 2009 7:33 pm ] |
I sure is glad we got da South Louisiana Mud Motor CSI team on it. |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:37 pm ] |
Oh ok BRO.......Wit smart ass comments llike this on every thread like you do I'm surprised someone towed your fukin ass in!!!! |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:39 pm ] |
Dude that sucks. Hard to believe something that small could cause something that major. If the leak in the carb boot caused it. |
Author: | schrieverboy [ Mon Oct 12, 2009 7:40 pm ] |
Author: | BODUKE_7 [ Mon Oct 12, 2009 7:45 pm ] |
can't we all get along ![]() ![]() ![]() |
Author: | OwenDickeson [ Mon Oct 12, 2009 7:47 pm ] |
all kiddin aside im sorry to hear about your motor. hope ya gets everythin back together before duck killin time. |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:48 pm ] |
Author: | deltaduckmaster [ Mon Oct 12, 2009 7:51 pm ] |
Author: | craig [ Mon Oct 12, 2009 7:51 pm ] |
Author: | OwenDickeson [ Mon Oct 12, 2009 7:52 pm ] |
Author: | LA OUTLAW [ Mon Oct 12, 2009 7:54 pm ] |
Author: | lil_catdaddy [ Mon Oct 12, 2009 7:56 pm ] |
Clear as mud ![]() ![]() |
Author: | OwenDickeson [ Mon Oct 12, 2009 7:58 pm ] |
Author: | deltaduckmaster [ Mon Oct 12, 2009 8:00 pm ] |
Author: | deltaduckmaster [ Mon Oct 12, 2009 8:03 pm ] |
Author: | OwenDickeson [ Mon Oct 12, 2009 8:04 pm ] |
Page 1 of 2 | All times are UTC - 6 hours |
