Speed
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=55232
Author:  bluemadness14 [ Wed Jul 30, 2014 6:32 am ]
Post subject:  Speed
I have a 1848 with 1/8 sides and 3/16 bottom. Wide open floor. I have a 35 hp sport. I'm running 29 with just me or a fully loaded boat. I have cam heads and exhaust. What would be the next best mod to get? Just really hoping to see over 30mph.
Author:  BDUBYA [ Fri Aug 01, 2014 6:56 am ]
Post subject:  Re: Speed
From what I've seen on here a prop could possibly get you an extra 3-5 mph.
Author:  pearl river outlaw [ Fri Aug 01, 2014 7:02 am ]
Get a carb and you'll be in the 33-34 range.
Author:  North LA Hunter [ Fri Aug 01, 2014 7:11 am ]
X2 on carb.
Author:  mudslut [ Fri Aug 01, 2014 8:26 am ]
Yea get a carb. You will be real happy with that set up.
Author:  BDUBYA [ Sat Aug 02, 2014 6:55 am ]
Mudslut
Did I see you on the Bend last year tryin to shoot a Can to mount?
Author:  Inkawhootz [ Sun Aug 03, 2014 3:57 pm ]
What rpms is 29 mph
Author:  mudslut [ Sun Aug 03, 2014 4:52 pm ]
Bdubya wasn't me but there's plenty out there if I wanted to mount one.
Author:  deadbird8 [ Sun Aug 03, 2014 8:29 pm ]
Author:  duckduckboom [ Sun Aug 03, 2014 8:37 pm ]
On the other site he says he runs the same with 4 people as he does empty. He has no responded as to the Rpms of either. From what I gathered on tos he needs to look into a diffrent prop
Author:  doubleBanded [ Sun Aug 03, 2014 8:49 pm ]
Get a carb
Author:  duckduckboom [ Sun Aug 03, 2014 8:51 pm ]
Why?
Author:  doubleBanded [ Sun Aug 03, 2014 8:57 pm ]
Bc he don't have one and he asked what's a good upgrade. Why not
Author:  duckduckboom [ Sun Aug 03, 2014 9:01 pm ]
So his carb is the problem? Cause I think he said he runs 4 people the same speed.
Author:  doubleBanded [ Sun Aug 03, 2014 9:11 pm ]
Didn't say that. Did I? He asked what a good upgrade did u miss that part? Or u so worried about what goes on over at tos? I haven't made it over there to read this post
Author:  duckduckboom [ Sun Aug 03, 2014 9:14 pm ]
So longer rods and flat top pistons?
Author:  bluemadness14 [ Tue Sep 23, 2014 2:42 pm ]
Sorry I haven't responded I haven't been here in a while. Took my boat out this past weekend and still seeing 29 mph solo. Took 3 buddies with me for a total of 4 people in the boat and running 28 bumping 29. From what I've read and seen on here usually people are running a few more mph faster running solo. Just seeing if you guys had any ideas. Also the rpms are right around 4400
Author:  bluemadness14 [ Tue Sep 23, 2014 2:43 pm ]
Also my prop is a new big blade
Author:  LA Prop [ Tue Sep 23, 2014 3:06 pm ]
If u put a carb kit u wont kill reliability and you'll gain a good bit from it
Author:  AKA Freshwaterkilla [ Tue Sep 23, 2014 4:07 pm ]
Author:  AKA Freshwaterkilla [ Tue Sep 23, 2014 4:10 pm ]
Author:  50fps [ Tue Sep 23, 2014 4:33 pm ]
$800 for 300-400 rpm.
:roll:
Author:  duckduckboom [ Tue Sep 23, 2014 5:50 pm ]
Author:  AKA Freshwaterkilla [ Tue Sep 23, 2014 5:52 pm ]
Author:  msm8281 [ Tue Sep 23, 2014 5:53 pm ]
He said smileys are for queers.
Author:  duckduckboom [ Tue Sep 23, 2014 5:53 pm ]
is your motor a cdi? who makes your cam? am i the only one who thinks if you are running the same rpms with a load as you are empty there is other things than a 800 dollar carb? maybe trade your cam for a cam with a little more duration?
Author:  bluemadness14 [ Tue Sep 23, 2014 7:13 pm ]
Yes its a cdi. And the cam is a pvt
Author:  duckduckboom [ Tue Sep 23, 2014 7:15 pm ]
Do you have 4700 coils?
Author:  cupped up [ Tue Sep 23, 2014 7:16 pm ]
Did you jet the stock carb? Change governor springs? Do anything to the stock carb at all? Is the tuneup right for the heads and cam?
Author:  bluemadness14 [ Tue Sep 23, 2014 7:29 pm ]
Yes I have 4700 coils. The guy that did my work said he reworked the stock carb for better flow.
Author:  AKA Freshwaterkilla [ Tue Sep 23, 2014 7:31 pm ]
Get rid of governor and stock carb setup u will be alot happier
Sent from my iPhone using
Author:  bluemadness14 [ Tue Sep 23, 2014 7:33 pm ]
Will the mikuni do away with the governor?
Author:  MNGunner [ Tue Sep 23, 2014 7:39 pm ]
Four dudes in a mud boat going 29mph?
Call 'er good and put the money your going to waste to go 2 mph more in your retirement account.
Author:  cupped up [ Tue Sep 23, 2014 7:43 pm ]
Author:  bluemadness14 [ Tue Sep 23, 2014 7:50 pm ]
He did jet the carb but he also said he grinded something down where instead of a 90 it was more of a 45. When it comes to carburetors I'm lost
Author:  AKA Freshwaterkilla [ Tue Sep 23, 2014 7:57 pm ]
Author:  North LA Hunter [ Tue Sep 23, 2014 8:03 pm ]
Author:  SCmudder7071 [ Tue Sep 23, 2014 8:23 pm ]
It'll do away with the governor but still won't turn over 4750 bcause of coils.
Author:  baron von [ Wed Sep 24, 2014 6:15 am ]
