Nick peltier
Joined: Wed Mar 19, 2014 8:10 pm Posts: 21 Location: Loreauville,LA
 36 HP vanguard shaving heads ?
Has any one had problems after shaving there heads .050 on a 36 HP big block vanguard ? Like detnation or some other type of issues ? Thinking about shaving mine .050 to get some more power out of the engine also will the stock head gasket be fine or will it be best to use a copper head gasket I know copper is better but is it nessary for this type of modification ?
| Tue Aug 19, 2014 10:43 am |
AKA Freshwaterkilla
 Re: 36 HP vanguard shaving heads ?
If u can find a copper gasket it's better but not necessary 50 thousandths depends on what other mods u havr
Sent from my iPhone using
| Tue Aug 19, 2014 11:11 am |
jerimiahw
Joined: Sun Sep 23, 2012 8:10 pm Posts: 1191 Location: chauvin
 Use stock gasket and you can go .060 you will be 185/190 psi run 93 octane you will be fine as long as you are using stock rods
| Tue Aug 19, 2014 11:12 am |
50fps
Shaved .055, stock gaskets, 190 psi on my tester w/ stock pistons and rods running 91 octane non-ethanol unleaded with no issues.
| Tue Aug 19, 2014 11:47 am |
Michaelk727
Sorry I know this is an old thread, but how much speed could I pick up by shaving the heads on my 36hp vanguard?
| Sat Apr 01, 2017 8:57 pm |
Will C
By only decking the heads only you will get a noticably more stronger engine with just a little bit mre top end.
| Sun Apr 02, 2017 10:05 am |
Michaelk727
So my motor would perform better with a load and out of the hole? And are there any cheap mods I can do to increase top end speed?
| Sun Apr 02, 2017 11:20 pm |
banded-mallard
| Mon Apr 03, 2017 4:42 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Carb, Heads, and exhaust will wake that puppy up! What goes in needs more space to come out=torque and speed increase!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Tue Apr 04, 2017 8:22 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
| Tue Apr 04, 2017 2:27 pm |
