| 36 HP vanguard shaving heads ? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=55872 |
| Author: | Nick peltier [ Tue Aug 19, 2014 10:43 am ] |
| Post subject: | 36 HP vanguard shaving heads ? |
Has any one had problems after shaving there heads .050 on a 36 HP big block vanguard ? Like detnation or some other type of issues ? Thinking about shaving mine .050 to get some more power out of the engine also will the stock head gasket be fine or will it be best to use a copper head gasket I know copper is better but is it nessary for this type of modification ? |
| Author: | AKA Freshwaterkilla [ Tue Aug 19, 2014 11:11 am ] |
| Post subject: | Re: 36 HP vanguard shaving heads ? |
If u can find a copper gasket it's better but not necessary 50 thousandths depends on what other mods u havr Sent from my iPhone using |
| Author: | jerimiahw [ Tue Aug 19, 2014 11:12 am ] |
| Author: | 50fps [ Tue Aug 19, 2014 11:47 am ] |
Shaved .055, stock gaskets, 190 psi on my tester w/ stock pistons and rods running 91 octane non-ethanol unleaded with no issues. |
| Author: | Michaelk727 [ Sat Apr 01, 2017 8:57 pm ] |
Sorry I know this is an old thread, but how much speed could I pick up by shaving the heads on my 36hp vanguard? |
| Author: | Will C [ Sun Apr 02, 2017 10:05 am ] |
By only decking the heads only you will get a noticably more stronger engine with just a little bit mre top end. |
| Author: | Michaelk727 [ Sun Apr 02, 2017 11:20 pm ] |
So my motor would perform better with a load and out of the hole? And are there any cheap mods I can do to increase top end speed? |
| Author: | banded-mallard [ Mon Apr 03, 2017 4:42 am ] |
| Author: | CypressCritter [ Tue Apr 04, 2017 8:22 am ] |
Carb, Heads, and exhaust will wake that puppy up! What goes in needs more space to come out=torque and speed increase! |
| Author: | pokey79 [ Tue Apr 04, 2017 2:27 pm ] |
