It is currently Wed Apr 01, 2026 6:07 am
Reply to topic  [ 7 posts ]
 What could cause this?
Post What could cause this?
ok guys I just installed my mikuni. my motor is definitely a different animal. idle and throttle response is night and day. my question is this. I definatley gained more load carrying ability and maybe a little too end but it seems to run out of prop or something. basically it runs the same speed at 3800 Rpms as 4100 Rpms. is that just all its going to do or is there something I can change. maybe a three bald prop. I am running a mudbuddy 12.5 big blade now. any ideas are helpful. thanks
35 Mud buddy Stage 2 on a 1844 Uncle J
Mon Sep 22, 2014 7:47 pm
Post Re: What could cause this?
You tried trimming down hair?
Mon Sep 22, 2014 7:49 pm
Tue Sep 23, 2014 4:39 am
I'm not sure what size jets and how carb is set up. the Carb was set up by boat dr. I need to do a comression/leak down test. And i am running a 32" outdrive.
Tue Sep 23, 2014 6:43 am
mine is doing the exact same thing. from 4100-5000 rpms my top end does not change. steady 26mph with a 2 guys and a load, in a non mud boat.
also running a 32" outdrive. I know my valves leak, but nothing terrible. I can only assume its prop slip. im running a 167.5 main, and eclip on position #2.
Tue Sep 23, 2014 7:48 am
So what can we do to fix this? Anything?
Tue Sep 23, 2014 9:34 am
Start over?
Tue Sep 23, 2014 2:08 pm
