Re: oil working out of the breather
isn't the breather assembly nothing more than a check valve? so if you have oil / air coming out it's installed properly!
x2 on what Beauford Joseph Guidry said
Also, i have seen a blown head gasket cause excess oil / smoke to come out of the breather. the gasket was busted on the inside around the head bolt that is in the middle of the push rod tubes.
