Basic engine troubleshooting and maintenance http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=5837 |
Author: | MaXXis85 [ Wed Nov 04, 2009 11:05 am ] |
Post subject: | Basic engine troubleshooting and maintenance |
Air filter low profile style found on 35/36 models Briggs part numbers Air filter 692519 Foam wrap- Filter precleaner 692520 Competitor brands K&N E-4665 Fram CA7726 Wix 42359 AC Delco A1500c Napa 2359 Purolator a25243 Round canister style found on 31/32 models Briggs part numbers Outer Air filter 841497 Inner Air Filter 821136 Competitor brand outer air filter Fram Ca9550 Wix 46438 Napa 6438 Competitor brand inner air filter Fram CA9550SY Wix 42985 Napa 2985 Fuel Filter Briggs 691035 Ac Delco GF505 Napa 3011 Wix 33011 SPARK PLUGS AUTOLITE APP3923 or AP3923- gapped at 0.35 according to Deadbird8 and others.... Champion-RC14YC NGK-ZFR5F-11 BOSCH-7527 or FR8 DC Briggs advises that the plugs be gapped at .030 Oil Filters Briggs 842921 briggs 492932S Ac Delco PF13 Napa 1348 Wix 51348 Compression Check http://www.youfixcars.com/engine-compression-test.html# Basic how to 1. disable ingition 2. disable fuel system 3. remove spark plugs 4. prop throttle wide open 5. attach compression gauge 6. crank engine 4 revolutions 7. record reading 8. use pressure relif to remove pressure 9. move onto next cylinder Leak down test eplained http://www.carcraft.com/techarticles/11 ... index.html Valve Adjustment http://www.allmudmotors.com/blogs/how-t ... 5-vanguard Briggs operators manual 35 HP horizontal shaft http://bsintek.basco.com/BriggsDocument ... 0HsjhJvcv4 Briggs part list for 35 HP Horizontal Shaft http://bsintek.basco.com/BriggsDocument ... lwEVJ1DajI Briggs operators manual 36 HP vertical shaft http://bsintek.basco.com/BriggsDocument ... KT9FzXFix2 Briggs part list for 36 HP Vertical Shaft http://bsintek.basco.com/BriggsDocument ... rvFVJ1DajI Recommended Maintenance Schedule for Vanguardâ„¢ Engines First 5 Hours Change oil Every 8 Hours or Daily Check engine oil level Clean area around muffler and controls Every 50 Hours or Annually Change engine oil Check muffler and spark arrester Every 100 Hours or Annually Clean air filter * Change engine oil and filter Check muffler and spark arrester Clean pre-cleaner (if equipped) * Replace spark plug Check valve clearance ** Every 400 Hours or Annually Change air filter Clean air cooling system * Replace fuel filter Clean oil cooler fins * Gator-Tail Owners Manual http://www.gator-tail.com/pdfs/GT%20Own ... %20PDF.pdf ProDrive Owners Manual http://prodriveoutboards.com/images/Pro ... nual08.pdf |
Author: | slambin [ Wed Nov 04, 2009 11:40 am ] |
Post subject: | Re: Basic engine troubleshooting and maintenance |
MAKE THIS A STICKY!!!!! |
Author: | basinhunter [ Wed Nov 04, 2009 12:57 pm ] |
I've seen this before ![]() |
Author: | hotdognjo [ Wed Nov 04, 2009 1:18 pm ] |
Most of it is here. viewtopic.php?f=3&t=41 |
Author: | MaXXis85 [ Wed Nov 04, 2009 2:12 pm ] |
^ you are right, BUT this has a little more information. Use whichever floats your boat bro! |
