It is currently Thu Sep 18, 2025 12:24 pm
[ 8 posts ] |
Different Charging System
Ace
Joined: Thu Jan 15, 2009 9:26 am Posts: 285 Location: Lafayette LA
I know there has been lots of posts about the stator charging system on the MM's. I know the GT's don't start charging back into the battery until 2000 r's. Question: Is there a different aftermarket stator that will charge as soon as you start the motor? I do a lot of idling and such and it beats up a battery pretty bad. Comeback FE's!
_________________ Ace Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Mon Nov 09, 2009 12:36 pm |
froghunter
 Re: Different Charging System
I do a lot of frogging and I have checked into that also, the only answer I got was that you need to run the engine for about 30 minutes. I was told that you can get a larger amp one but all takes about 2200 rpm to start charging.
_________________ Homemade 18' X 48" with HD 4000 Mudbuddy and looking for more
Mon Nov 09, 2009 12:56 pm |
brlcla
Joined: Tue Jan 13, 2009 5:11 pm Posts: 955 Location: Lake Charles, LA
The new marine grade charge 20 amps at idle and 50 amps above 2000 rpms.... may be able to retrofit your engine depending on age of the motor.
Mon Nov 09, 2009 6:18 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
Mon Nov 09, 2009 6:39 pm |
LA OUTLAW
Joined: Mon Mar 02, 2009 9:25 pm Posts: 1096 Location: Morgan City
I was told by the mechanic for prodrive in franklin, LA that it was not possible to retrofit them with the new charging system.
_________________ 1754 GT EXTREME 37EFI
Tue Nov 10, 2009 7:07 am |
jpc014
Joined: Tue Mar 10, 2009 8:17 pm Posts: 785 Location: Meraux, LA
HRCH Cajun Black "VOODOO" Magic 18x48 Center Console PD w/32PDHydro T&T; Hydro Reverse "If I wanted any of your lip; I would pull down my zipper"
Wed Nov 11, 2009 3:55 pm |
OwenDickeson
Wed Nov 11, 2009 6:00 pm |
deadbird8
Thu Nov 12, 2009 7:25 pm |
[ 8 posts ] |
